Cpu 60°c help
Go to solution Solved by Levent,
Columns are "current", "minimum" and "maximum". Your CPU package is currently 46c. its not "ideling in 60c"
https://linustechtips.com/topic/1571277-cpu-60%C2%B0c-help/#findComment-16418078
6 minutes ago, DASADAS said:
image.png.0f29b08c45a0bd4db6bfa3f38d68a1c6.pnghelp why is my cpu ideling on 60c
It would be a ton of help if you gave us the exact CPU, the cooler you're using, average temps usually and the average temperature of the area you stay in. Also check what's running in the background. And current cpu utilisation and performance.
So like the whole hwinfo window + the cooler you're using.
Completely missed that. Idk what he expects us to do without giving the full picture.
Edited by okkee
Completely missed something
https://linustechtips.com/topic/1571277-cpu-60%C2%B0c-help/#findComment-16418080
Your package was as low as 40°C at one point,
they have 6P cores and 8E cores, they have 13600(k)/13500(k) Intel,
13600 max turbo power is 154W, it's a literal Heater,
in other words unless it's reaching 80-85°C while gaming it's okay
current PC:
PC configs I used before:
https://linustechtips.com/topic/1571277-cpu-60%C2%B0c-help/#findComment-16418095
Yeah. I was thinking he was concerned about massive increases while gaming but now I'm thinking he's just slightly confused and I'm just a bit of an idiot.
https://linustechtips.com/topic/1571277-cpu-60%C2%B0c-help/#findComment-16418124
