Need help finding a monitor
LittleCarrot
Hello LinusTechTips's Forum Users,
I need a monitor that is the same height as my current monitor:
Samsung 27-Inch Curved LED-Lit Monitor S27D590C.
I need this monitor to be an ultrawide.
"In the middle of every difficulty lies opportunity."
- Albert Einstein
just get another 2 and run them in surround
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
It needs to be the same height as my monitor (
Samsung 27-Inch Curved LED-Lit Monitor S27D590C)
This monitor needs to be an ultrawide. Thanks
- Albert Einstein
In a 21:9 resolution displaywars.com says that you'd need a 34in monitor.
From there it's up to you, pick out what you like (and has good reviews I would hope).
"You should look up common sense and add it to your vocabulary." - dougdangger 2015
is your current monitor an ultra wide or 16:9?
if its a 16:9 then get an LG 34-inch ultrawide
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
thats pretty surprising actually.. i thought the difference between the two would be way bigger
I thought the opposite at first honestly.. I guess I didn't have such a good perspective on how short ultrawides really are
I Currently Own a Samsung 27in Curved Monitor (non-ultrawide)
I want to find a ultra wide the same height as the Samsung One. I needs to be from Amazon thanks.
- Albert Einstein
i know I had a 25in ultrawide. My brothers 21in was the same height.
- Albert Einstein
Is this a good choice: http://www.amazon.com/Acer-Curved-34-inch-UltraWide-Display/dp/B0111MRT90/ref=sr_1_11?ie=UTF8&qid=1448936722&sr=8-11&keywords=34in+ultrawide+monitor
- Albert Einstein
I'm pretty sure that's the non-Gsync version of the Predator X34, and if it's anything like it then yes it pretty good.
Any cheaper alternatives?
- Albert Einstein
I'd probably recommend the one you posted out of the one's I've seen.  I'm a little partial to Acer, but a second choice would probably be Samsung's ultrawide.
i am surprised you have not mentioned lg
- Albert Einstein
It's probably 3rd pick.  I've heard some stuff about pretty bad light bleed with the curved ultrawide.
Is there a lot of support for ultrawides. When I got mine this year. None of my games were compatible so i exchanged it for a lovely curved 27in samsung.
- Albert Einstein
I wouldn't know because I don't have one, but from the research I did when I looking into one it's not there just yet.  Some games don't support it, some games do, but the UI is funky.  Some games will run perfect with it.
I'd research the games you're playing to see how they work with 21:9
I dont plan on to game on the display. Should I get a ROG  Gsync Pannel
- Albert Einstein
If you're not gaming there's no point in spending extra money to get a Gsync panel
