Whats You're Audio Settup
Im sorry if i posted this in the wrong place or if there is already a thread for this
my phone mic was distorting not the speakers i was now ware neer pushing them  http://vocaroo.com/i/s1AI9XwQR8l0
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/459139-whats-youre-audio-settup/
Snip
Your*
Hehe
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161280
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161285
jesus christ i think the combined power of your speaker system is enough to run crysis 3
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161294
if that is yours then F*CKING HELL your street must not be happy
lol i bet he uses it to listen to katy perry (i kid, i kid)
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161316
not to brag, but...
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161324
Logitech LS21. They may not be much at all but I like the sound they produce. I've also messed with the EQ in Realtek Audio Manager so they sound even better than normal.
The bass is a bit lacking, due to the small(ish) subwoofer, but as long as you don't crank them too much the sound doesn't distort.
PC - Ryzen 7 2700X, ASUS B450-PLUS, 16GB ADATA XPG DDR4, Gigabyte GTX 1660 SUPER, 500GB PNY XLR8, 1TB WD Green, Corsair HX750, AMD Wraith Prism, Phanteks Enthoo Pro, 2x Acer Nitro 27" 1440P IPS, Corsair K65, RGB mouse, Razer mousepad!
Mac - 2015 Macbook Pro Retina 13" (2.7 i5, 8GB, 256GB)
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161327
not to brag, but...
-snip-
Holy mother of God. Are you sure you have enough speakers? I feel inadequate now :)
For general use:
For gaming:
Other systems I've built:
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161331
yeah its mine lol
i dont turn it up at night, people upstairs are cool with it :)
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161342
I use a Sharp XL-DAB151 for music and such
Plantronics Gamecom 780 for gaming/music at night
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161357
yeah its mine lol
first how much
second how many watts
third how loud is it
and do you want to swap :P
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161381
Have you considered trying one set of good speakers rather than 5 (6?) sets or rubbish speakers? (Oh the offense!)
I'm planning to buy some $2k studio monitors when I move
I just wanted to have cheap surround sound with lots of speakers that look awesome
and more than just 5.1
The sound quality is actually pretty good, the receiver I am using is a sony 5.1 which I bought new
sound quality depends more on the amp than the speakers, so its not bad, and definitely loud enough
It obviously doesn't have a flat EQ due to the mixing of different types of speakers with different ranges, but it gives the sound a warm "hall" style effect (but without the reverb)
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161465
first how much
less than $1k for everything
about 1500W
too loud, I always have it on like 5% xD
no, but I will be selling this stuff before I move out probably in the next year or two
you can find a lot of stuff like this on craigslist for really cheap
the receiver is the most expensive part, I bought that new 3 years ago
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161476
Every time I see this I want this.
My speakers all small in comparison.
I'll post a pic of my speakers soon. I have:
Onkyo tx-sr606
4 Polk r15 speakers
Not very good Polk psw108 sub
Then my new HH Scott c-10 speakers for music with 10" woofer and 3" tweeter
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6161659
I have some Yamaha HS7 Studio Monitors as well as the Yamaha HS8S Subwoofer. For my headphones i have a pair of HD800's, HD600's, HD700's and HD8DJ's. Powering them is my Parasound Zdac which feeds into my Burson Audio Solist Headhphone amplifier. I also have a Debut Carbon Turntable to listen to LP's. Nothing too over the top. Here is the most recent picture of my setup, doesnt have everything, but for the most part thats what it looks like now.
Main Rig: | CPU: Intel Core i9-7900x | GPU: Nvidia RTX 2080 Founders | Mobo: Asus ROG Strix X299-E Gaming | RAM: 32GB Corsair Vengeance LPX DDR4 3000 MHz | SSD: Samsung 980 Pro w/Heatsink 1TB & Samsung 960 Pro 1TB | Sound: Parasound ZDAC & Burson Soloist Amp | PSU: Corsair RM850 | Fans: 2x Noctua NF-F12 | Case: Caselabs MAGNUM SMA8 | Headphones: Sennheiser HD 800 | Keyboard: WASD V3 | Mouse: Logitech G502 Lightspeed | Mousepad: Logitech G PowerPlay | CPU Cooler: bequiet! Dark Rock Pro 3 | Primary Monitor: Acer Predator XB272 | Extra Monitors: Samsung Syncmaster PX2370 |
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6162146
too lazy to take pictures.
Livingroom:
2 Onkyo SK-60 Tower Speakers
2 Micca COVO-S Back Speakers
Micca Micca MB42X-C Center Speaker
Dayton Audio SUB-1200 Subwoofer
Sony STRDH520 Receiver
Desk:
2 Micca COVO-S Speakers
Dayton Audio SUB-1000 Subwoofer
Powered by Lepai Amp
Headphones:
ATH-M50 (modded with detachable cord, Slanted NVX pads), Hyper X Clouds 1 & 2, Pioneer SE-A1000, Superlux 668B, CHC Silverado, Panasonic HTF600 with Shure 840 pads, AKG K7xx, NVX XPT100, (about to have) PSB M4U 2, Phillips SHP9500
Internets Machine: Intel 4690k w/ Be Quiet! Pure Rock 4.7Ghz. MSI Krait z97. 16GB Crucial Ballistix Sport Ram. MSI GTX 970 SLI 1520mhz. 500GB Samsung EVO 840  & 3TB WD Blue Drive. Rosewill 1000w Modular PSU. Corsair Air 540
My Beats Yo: Desktop:SMSL SA-160 Amp, KEF Q100 w/ Dayton 100w Sub Theater: Micca MB42X-C x3, MB42X x2, COVO-S x2 w/Dayton 120w Sub Headphones:  HIFiMan HE-400i, PSB M4U2, Philips Fidelio X2, Modded Fostex T50RP, ATH-M50, NVX XPT100, Phillips SHP9500, Pioneer SE-A1000, Hyper X Cloud 1&2, CHC Silverado, Superlux 668B
https://linustechtips.com/topic/459139-whats-youre-audio-settup/#findComment-6165125
