Get rid of that PSU and try to squeeze in an SSD too. Anyway, the NZXT S340 is looking pretty good, I'd give that one a try :)
Other systems I've built:
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160311
Please.... Do..... Not.... Buy.... CX.... PSUs.... Never.....
Do you people know WHY they are not good? :)
At OP, Get something like a EVGA GS or G2, any XFX or SeaSonic PSU also works.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160328
They are perfectly fine for a 750Ti/860K or less. Basic builds.
There are usually better options for the price bracket, but otherwise, for a build like you said it is fine.
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160332
I had a CX psu die on me a few months ago.. :3
That could be bad luck. Do you actually KNOW why? A $300 EVGA T2 1600w Could go out on someone with something as low as a pentium and R7 370.
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160349
I agree, I think "never" is a bit strong, but they really don't belong in a PC like this IMHO :)
Very low ambient temperature tolerence (30 degrees IIRC) and low quality capacitors, isn't it?
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160350
do you think the eVGA 600B Bronze is a good psu
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160353
Correct! A lot of people just jump on the bandwagon and say it since everyone else does.
Also, @WesleydeGroot Look into the BeQuiet! Pure Rock, it is better then the 212 Evo for about the same price.
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160363
This PSU is much better and the same price:
PCPartPicker part list: http://pcpartpicker.com/p/M66DkL
Price breakdown by merchant: http://pcpartpicker.com/p/M66DkL/by_merchant/
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Total: $54.99
Generated by PCPartPicker 2015-09-30 11:27 EDT-0400
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160376
There you go
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.99 @ SuperBiiz)
Motherboard: ASRock Fatal1ty Z97X Killer ATX LGA1150 Motherboard  ($127.98 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card  ($324.98 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($63.99 @ SuperBiiz)
Total: $898.80
Generated by PCPartPicker 2015-09-30 11:32 EDT-0400
"an obvious supporter of privacy"
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160396
srry guys forgot to change the psu xD
MAKE SURE TO GET A z97
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160400
Nice, congrats. Doesn't change the fact they they're still usable and aren't as bad as you make them out to be.
i does have good reviews for the most part,  i mean i wouldnt power 4 titan xs and a 5960x on it but it will do fine
https://linustechtips.com/topic/459062-cool-case-for-my-build/#findComment-6160473
