Can any one suggest me? :) to play games on my PC at ultra high configurations but i am confused between ATI radeon and Nvidia geforce GTX. whose GPU is best for such performance and gaming & which one? and also differentiate me the both GPUs's specs and how they help. people select nvidia but some say radeon, help me plz. Suggest me the best graphics card for gaming?
https://linustechtips.com/topic/45529-best-graphics-card-for-gamming/
The best card overall is the GTX Titan, but what is your budget? If you want great bang for the buck I recommend the AMD 7950
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
The most power single gpu? Gtx Titan.
Specs don't matter most of the time and you want to focus more on benchmarks for whatever you want to do with it.
What's you situation? Are you upgrading the graphics of a preexisting system or making a new one altogether?
Best card: Titan. Best card you're most likely looking for, and might buy: GTX 780 SLI.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
7950 is a great choice, but yes the Titan is the most powerful single chip card. What's your budget?
MSI Z68A-GD80 (G3) | Core i7 2700K @ 4.7GHz | EVGA GTX 580 1.5GB @ stock
8GB G.Skill RipjawsZ 2133MHz | OCZ Agility 3 60GB | 3x500GB RAID 5 | DVD-RW
Xclio Nighthawk | OCZ ModX Stream Pro 700W | CM Hyper 212 EVO with Corsair SP120s push/pull
7990 all the way ^_^
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
Gamming? like this gamming> Gamming: Nautical . (of the officers and crews of two whaling vessels) to visit or converse with one another for social purposes.
I don't think a graphics card will help you in that situation, better go with small talk instead.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
if nvidia -600 and above(most probably the 700 series now) and if amd the 700 series. if you can wait for a little bit time you can (maybe) have a 9xxx series gpu.  as for my concern 700 series is good(780) and the titan.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
Before the latest drivers came out, that would have been a terrible suggestion.
>_> RadeonPro pretty much fixed the micro-stuttering problems anyway just not many people knew about it.
If you have the money, the GTX 780 is a BEAST card.  Yes the Titan is better, but it is around $400 more for not that much performance gain in games.
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
If you can wait the 9970 might be what you're looking for, if you can’t the 780 and Titan are your best bet for single GPU gaming performance.
Case: Corsair C70 GunMetalBlack, CPU: Intel 3570k, Mobo: Asus p8z77-v lx, CPU Cooler: BeQuiet! Dark Rock Pro 2, RAM: 8GB Corsair Vengeance 1600Mhz lp, Video Card: Asus HD7950 DC2 Top V2, SSD: Samsung 840 pro, HDD: one Seagate 2TB Barracuda, PSU: BeQuiet! Dark Power pro 10 650w, Monitor: Dell UltraSharp u2412m, Keyboard: CoolerMaster QuickFire tk (Brown Switches), Mouse: Steelseries Sensei raw, Sennheiser HD 558
Want ultra graphics? Wait for the Xbox one!!!!!! But seriously, Quantum says it best. If you have the money go with the 780.  Titan doesn't make sense unless you have a lot of extra cash sitting around.
| Currently no gaming rig | Dell XPS 13 (9343) |
| Samsung Galaxy Note5 | Gear VR | Nvidia Shield Tab | Xbox One |
with the new games needs, minimum... a 7950  B)
Nice consensus. GK110 if you have the cash otherwise get a 7950. If you need more fps, but another 7950.
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
I doubt a 7770/7790 wouldn't have any problems with even the newest games...
A 7950 would be if you couldn't stand anything lower than high for settings.
I have an Asus 760 OC... I would recommend it to anyone. It's a great card and it's not too expensive.  A little less than $300 I think.  Anyways you could get 2 of those and SLI them together.  Also this graphics card comes with a software called GPU tweak, which allows you to very easily overclock the GPU.
A 7950: http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026 or the 7970: http://www.newegg.com/Product/Product.aspx?Item=N82E16814202008
These two cards are great cards for overclocking and offer great performance for the price.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
88 way sli titans on liquid oxygen. WHAT DO YOU MEAN PRICE WISE. ME NEED PRICE.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
