Do these coolers fit in my case
Go to solution Solved by tomas710,
http://www.mycom.be
http://www.alternate.be
But, do you know if they mesure the depth of the case from side to side or from socket to side?
Get this one, it will fit on your case and cool better and quieter than the hyper 212 evo
https://www.alternate.be/be-quiet!/Pure-Rock-CPU-koeler/html/product/1146249?tk=7&lk=6098
This is the one i recomended before, it will fit and be better than a hyper 212 evo
https://www.alternate.be/Cryorig/H7-CPU-koeler/html/product/1174912?tk=7&lk=6098
This one costs a bit more but would outperform the other coolers
https://www.alternate.be/Thermalright/Macho120-Rev-A-CPU-koeler/html/product/1110491?tk=7&lk=6098
The measurment for cooler clearence is meant to mean that the height of a given cooler is the max allowed in that case. Since a milimiter can be within margin i rather go with something i know will fit, and all 3 options i presented will fit, will perform better than a hyper 212 evo and will be quieter.
I'm stuck with choosing a cooler for my pc.
I have an AMD FX-8320 and the stock cooler sucks.
I'm planning to buy an aftermarket cooler but i can't find if the coolers will fit in my case.
My case is the Sharkoon vg4-w and i'm having doubts between the cooler master hyper 212 evo and the cooler master seidon 120v ref 2.
If someone has this case and one of these coolers in it please answer my question.
Both coolers will fit based on the specs of the case and coolers.
You should be fine. :)
Vulcan (Main): Intel Xeon E3-1241 V3 | MSI GTX 1060 Armor OC | G. Skill Sniper 16GB + 4GB @1600  | Crucial BX100 120GB, 1TB WD Caviar Blue, 2TB Seagate Barracuda, 1TB External Seagate Portable | EVGA 650 GQ | Cryorig H7 | NZXT Source 210 Elite
Carbon (Laptop): Lenovo ThinkPad x230 | Core i7 3520m | 8GB Memory (2x4GB)  | 180GB SSD, Sandisk Ultra 128GB SD Card
The Hyper 212 Evo is 159mm tall, your case allows 160mm, so technically it fits but for me it would be too tight. The CRYORIG H7 is a similarly priced cooler that's better and not as tall, so should be better for you overall. I wouldn't try a water cooler on your case because there are no rad support specs on the site and that could mean no clearence. Also, 120mm watercoolers are not worth it.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
Thanks everyone for helping me out :)
Do you have any other alternatives cuz I live in Belgium and it's not available here :(
What you got available? can you give us a site from where you can buy stuff?
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
http://www.mycom.be
It would have to be from socket to side because that's where the cooler will be sitting.
http://www.mycom.be
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
By the way man, i live in Chile...and trust me, i wish i had your alternatives. All thermaltake and cooler master here...
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
Thanks for the answer but if i would go with the termalright, is it gonna fit?
I have the MSI 970 gaming motherboard.
Isn't it gonna touch the ram sticks, because i can't find how far they are from the cpu socket :/
If you got high profile memory the fan may not fit on that side, if that's the case, you can put the fan on the other side of the heatsink
EDIT
That picture doesnt make a lot of sense tho, that mobo has 2 dimm slots on each side, so compatibility would be compromised, in a normal ATX mobo it should be fine.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
Ok, thanks for the advice :)
I have corsair vengeance 1600 2x4 GB I assume that's high profile.
