How do I start out in Tech Reviews on YouTube?
With great difficulty.
First things first, remove any preconceived notions of being able to do it as a job. Do it because you enjoy it, not because you think it can be a job.
Second, learn and practice how to present. You need to sound interested and engaging, people won't listen to you waffle on about whatever it is you're talking about if you don't sound the least bit interested. Additionally, you don't have to be perfect, if you mess up a line, either continue forwards (if it's something small) or start the line again and cut it out (if it's something large or you pause for a bit)
Third, you mentioned a owning a blue yeti. Use it. It's simple enough to sync up your mic with your camera if you clap, and your videos will sound much better
Fourth, if you have access to some lighting, light your set or shots decently. Even a desk lamp will look better then the limited amount of light you may get otherwise (although this is one of the things that may not be too important)
Fifth, even if it is just movie maker, learn the features of your editing software. Knowing all you can get out of it is rather useful. At the same time, also know what features not to use, like auto lighting or most transitions
Sixth, if you want to use music, get royalty free music. It may take a while to find some, but it's better then having your video deleted cause you had Gangnam style in the background.
And seventh, learn to take criticism and advice. A lot of people don't do this well (such as the people who want to get rid of the dislike button). If people give good useful advice, take it on board. If not, ignore them, or block them if they're too bad.
EDIT - And before I forget, don't try to suck up to companies and avoid critisising them in order to get review products. People will see right through that.
