Tools required to build a gaming PC?
Well, you could build a PC with just a normal good screwdriver. buuuut.
what i would reccommend issss
1 MAGNETIC good screwdriver, the amount of screws i've dropped into my PC case is too much :'D. maybe 2 of them for different size screws
2 Anti Static wrist strap
3 Well lit room and you'll maybe want a torch with it too.
4 something to store your screws in, like a cup or magnetic parts tray, along with other stuff
5 cleaning alcohol, incase you are putting on a cooler with pre applied thermal paste but you have your own (if it's better)
6 zip ties or velcro straps or twist ties (i can't spell ), good for cable management
7 a cloth, if your hands get sweaty sometimes screwing stuff in gets hard as nuts (geddit? ), specially one's for the case fans which require a bit of muscle compared to normal screws (unless they use normal screws for newer ones now)
8 maybe the case box for storing stuff like side panels in, also i notice linus reccommended using the motherboard box as a temporary test bench.
9 Spare PC or Laptop Or Tablet on hand, it's damn handy to have incase you get stuck at something, other than that it could provide some music while you do it.
10 Manual
optional
1 Band aid, ....Sometimes accidents happen, don't want your new PC to have blood on it if you have an accident....unless you want to enter brotherhood with it .
2 Pliers/Wrench, a screwdriver and hands should be fine for most things, might be handy with the front panel connectors.
3 Mastering martial arts, .... Front panel connectors >:C, So you can ethier learn patience required sometimes or you karate kick the thing out of the window
