To Vsync or not to Vsync
CalumGiff
Should i use vsync and accept the 30fps cap that it comes with on certain games or turn it off and play with full 60 fps?
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
What is your minimum, maximum and average fps?
Depends on the game, but I turn it off on every single game. unless I can't.
If framerate drops aren't noticeable to you, go for it. Personally, I limit my FPS to get a consistent image. I'd rather game at 40 FPS with no drops than game at 144 with drops down to 20.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
only games i have it on are games like garrysmod and portal 2 where I get like 300fps and vsync is a must or else the tearing is unbearable.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
depends if you experience screen tearing
Desktop:
CPU : i5 4440 | Motherboard : Gigabyte B85M-D3H | RAM : Kingstone HyperX blu 4GB x2 | GPU : Asus R9 280X DC II Top [RIP 2017] | PSU : Corsair VS 550W | Display(s) : Dell S2240L | Mouse : Logitech G400s | Operating System : Windows 7 64bit
Laptop:
Acer Predator Helios 300 (CPU: Intel Core i5 7300HQ | GPU: GTX 1050ti | RAM: 16GB RAM | Operating System: Windows 10 64bit)
I Vysnc everything that is not a competitive multiplayer game.
AMD Phenom II B55 Quad / unlocked dual core 4.3ghz CB R15 = CB 422
XFX R9 390 8GB MY RIG: http://uk.pcpartpicker.com/p/MVwQsY
Fastest 7770 on LTT . 3rd Fastest Phenom II Quad on LTT
PCSX2 on AMD CPU? http://linustechtips.com/main/topic/412377-pcsx2-emulator-4096x2160-amd-phenom-ii/#entry5550588
i would suggest using MSI rivatuner, you can assign fps from 1 - 99 fps if turning v-sync only gives you 30 fps cap.
Rig: CPU: Intel I7 4790k @ 4.5 ghz | MOBO: MSI Z97 Gaming 3 | RAM: 4x4 gigs Kingston Fury 1600 ddr3 | GPU: MSI Geforce GTX 1070 Gaming X PSU: Seasonic M12ii-620 Evo Edition | HDD: 1 TB WD, 500 GB WD | SSD: Kingston SSD now 240 and 120 GB CASE: In Win 303 RGB edition | Mouse: Corsair m65 pro | Keyboard: Roccat Ryos MK | Headset: Hyper X Cloud Pro  | Monitor: LG 29um58-P Ultrawide monitor.
Depends on the type of game I'm playing. I go for no vsync on FPS games. But sometimes I turn it on in some slower paced games where there is no need for over 60 fps. It keeps my PC and laptop cool, doesn't force the hardware and keeps the fan noise down. :)
If you play at 60fps without vsync you'll play at 60fps with vsync.
I personally keep vsync enabled all the time. Screen tearing drives me insane in fullscreen mode, and disabling vsync in windowed mode often causes micro-stuttering since Windows "forces" vsync regardless.
i7-5820K | GTX 980 Ti
I don't see a reason to use V-Sync for 30fps... I'd prefer runs it at 40, 50, ... than 30!
But... if a game is running like fps>60 all the time... I turn the V-sync on! There is no reason to GPU render 300 frames! 60 is enough.
Play in Windowed Fullscreen with V-sync disabled in game.  You get the best of both worlds, less input lag compared to V-sync and no screen tearing
But micro stutter if you can't keep 60fps
My r9 280 goes crazy with coil whine if I turn off v-sync in high fps games. Hey it was only $50, and 1 day used before I got it. I can live with it.
My AMD Build:
FX 6300 @ 4.8GHz, Zalman CNPS14X, MSI 970 Gaming, 16gb 1866MHz AData Ram, 3D Club R9 280X, Corsair 600M Psu, Thermaltake V3 AMD Edition Case, D-link 1200AC WiFi, 240gb Mushkin SSD, 2tb WD HDD, 140gb WD HDD (recording gameplay), 5x CoolerMaster SickleFlow 120mm fans, Windows 10 64Bit
Sisters Intel Build:
I7 4790k @ 4.4GHz, CoolerMaster 212 Evo, Gigabyte Gaming 5, 16gb 1866MHz Corsair Ram, 3D Club R9 390, EVGA 650GS Psu, NZXT S340 Case, D-Link 1200AC WiFi Card, HyperX 240gb SSD, 2tb WD HDD, Windows 10 64 Bit
