PCIe 3.0 riser cable issues?
Go to solution Solved by IkeaGnome,
In the motherboard BIOS go into your PCIE settings and force your PCIE into gen 3 instead of Auto.
A gen 3 riser between gen 4 components will cause weird issues.
Hello, everyone!
A little bit of context:
I am running a Core i7-14700KF with a Z690 chipset MOBO paired with a MSI 3070 slotted in a 4.0 16x port. Running a freshly installed Windows 11.
I upgraded from a Z170 chipset and Intel 6th gen CPU. The GPU was not upgraded which was slotted to a PCIe 3.0 16x slot with an EK Riser cable -I assume the riser is also 3.0, but cannot be 100% sure-.
I was also using Windows 10.
Now I am noticing that playing Final Fantasy XIV at 1080p will max out my GPU utilization to 99% most of the time, and playing a video on a secondonitor at the same time will start to stutter and run very poorly probably because utilization is at 99%.
This didn't happen before the upgrade. And doesn't happen with a second similar setup before the upgrade.
I made sure I have the latest drivers.
Can a PCIe 3.0 riser cable connected to a PCIe 4.0 slot be the culprit?
How can I be certain that the cable os indeed a 3.0 one?
Thank you!
https://linustechtips.com/topic/1569358-pcie-30-riser-cable-issues/
Sorry, but your post is a little difficult to read for people that have their page set to the "dark" mode.  Makes it a lot easier on the eyes for a lot of people like myself.   The only thing that I could read normally was the Thank you! at the end of the post.  Sorry.
Take care and good luck.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
i get slightly annoyed with this as well, but really not a big deal. you can just highlight it and see it fine.
Sorry about that. Just copied from another browser and didn't notice. Fixed it!
That makes a lot of sense! I forgot you could do that in the BIOS. I'll try that! Thanx.
2 hours ago, Robchil said:
test without the riser cable
I can't the custom watercooling loop will not let me... Well I can, but ot will be A LOT of trouble and time to test without it.
why not?
always keep a few barb fittings and soft tubes, to either test card in different configuration or remove it entirely..
and to easier drain, a drain valve at the top and bottom of the loop. i have a stop valve too.. to easier drain each side of the loop.
