CPU/GPU Temps?
Go to solution Solved by GeeZillion,
Your are saying that my GPU and CPU are fine WAT!
CPU temp is 72C and GPU 79C, and my GPU was designed to run at 80 C
those temps are fine modern CPU's are made to withstand temps of 100c but as long as there both under 85c your perfectly fine but it would be nice for them to run cooler but it's fine running at thst temp
Okay, CPU and GPU temperatures are scaring the crap outta me.
To make you understand why i'm so scared, i paid 435 EURO for my parts. And i worked 7 Hours for only 10 EURO, I was saving money for 4 Years.
The lucky day is when i found job, cause my country fucking sucks! Hard to find job or little paid.
And now, my case sucks at airflow (That is my old case, really bad airflow and no fans) So i have to keep my case opened all the time literally.
My CPU is I3 4150 (72C)
My GPU is MSI R9 280X (79C)-(81C)
New case that i'm planing to buy is
http://www.olx.ba/artikal/17523065/kuciste-aw-c201-crni-2x12cm-fan-usb-3-0-tool-free/ Andit costs 40 EURO
My PSU gets so hot that i can't lay my hard on it for 10 seconds
https://linustechtips.com/topic/380179-cpugpu-temps/
Yes, the case will be much better. More fans is better.
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136396
Dude mods do not have any more knowledge than other people on the forum,
Ideally you need a new case and a better cooler,
if your PSU gets that hot, maybe its faulty and causing your other components to get hot?
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136398
Get new case.
Pack it full of fans and bask in the flow. of air
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136440
First off the mods are not the only people that can help you, this is a trivial issue at best so I would avoid topic titles like this in the future.
On topic-
The CPU/GPU temps are actually fine, though you should check to make sure your PSU's fan has access to some airflow. If it's at the top of the case and the fan is facing towards the top of the case and there is no ventilation then you need to turn the fan down towards the inside of the case. If the PSU is on the bottom of the case with the fan side down then you need to be sure that there is space between the case and the floor. If there is no space then you either need to make space or flip the PSU the other way round to be sure it can breathe. Also that link went nowhere for me.
"The of and to a in is I that it for you was with on as have but be they"
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136492
Ambients : 30°c
Difference is 42 and 49°c .
If it's designed to run at 80 and it runs at 80 it's fine  .
I have a R9 290 and it runs at 95°c, and it's designed to run at that.
I would be more worried about PSU
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136502
No the thermal threshold for a 280x is way higher than 80*C
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136511
You dont want PSU to fail.
Just post full specifications and make a picture of the thing and post here.
You have some options:
- Buy fans
- Buy case
- Downvolt and downclock
And if PSU is crap, id go with better psu first.
Thats load temps right?
yes
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136590
- Buy fans
- Buy case
Is this a good case?
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136612
You don't need mods for this and you didn't even ask a question in your post...
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136760
https://linustechtips.com/topic/380179-cpugpu-temps/#findComment-5136881
