Titan Z not running in SLI
jgv115
Hi everyone,
Ever since the latest Nvidia driver, it seems my Titan Z can only run off one of the 2 GPUs. I can't see the SLI option in the GeForce control panel. However, I still see 2 Titan Z listings in device manager which says to me that it's likely to be a driver issue perhaps.
Just wondering if anyone has any idea on how I could try to fix this?
WTF you have two titan z's?
A titan z is one card, with 2 graphics chips on it.
2 cores on one pcb.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
do both of them show up in the nvidia control panel, or only in device manager?
You can always revert drivers as a temporary fix, but it does seem weird...
I never knew someone actually owned a Titan Z...
But try an older driver, did that allow SLI?
TotalBiscuit owns a Titan Z...
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
I never knew that, I don't watch him; he's boring as fuck.
He's running duel 980's i believe, unless the bastard upgraded again to X's. Pretty sure before the 980's he was running dual Titans, not a titanZ.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
Hmm... device manager shows 2 TITAN Z entries (which is normal) but EVGA Precision X only shows 1.
It seems like the only thing I can do is to revert to a previous driver, which I'm quite reluctant to do.
Anyone else have any ideas?
post-34749-0-78238600-1432975557_thumb.p
The windows device manager is showing the correct entry - a dual gpu card should show up as two separate entries.
I've had a couple issues with the latest whql GeForce drivers but my cards run fine seemingly otherwise so I'll just wait till the next one rolls around and hope it fixes them - not the most scientific approach I know.
At least try and revert to an older driver that you can confirm works with the SLI option so you can eliminate one possible cause - you don't have to keep using it thereafter if you don't want to.
Okay, I reverted back to 347.88 and I have SLI again. This is so weird. I guess I'll keep this version until the next driver comes out.
I guess this is sort of expected since there aren't many Titan Zs out in the wild...
Sli cable attached? [emoji3]
Core I7 5960X / Gigabyte X99 SOC Force / Kingston 16GB DDR4 3000 / EVGA GTX 980 Classified's In Quad SLI / EVGA 1600W G2
Core I7 6700K / Asus Z170 Maximus VIII Hero / Corsair 16GB DDR4 3000 / MSI R9 290X Lightning / EVGA 1600W T2
