Is too low CPU temperature bad?
Solved by minibois,
I heard somewhere that too low cpu temperatures are bad. My PC is almost as cool as the room temperature and I dont know why. I wanted to add fans, but im scared it will mess it up somehow. So is it bad?
It can only go too low if you are using liquid nitrogen to cool.
That way condensation can build up, so you have to protect your CPU for that.
Room temperature must be 20+ C, which is not too low for a CPU.
Featured Topics
eric_s ·
Posted in Power Supplies4 -
1
Silencix ·
Posted in Cases and Mods1 -
4
LambdaBird ·
Posted in General Discussion5 -
2
12
4
2
