Sound card question relating the Sennheiser HD 650
@WereCat @Samfisher @creatip123 @Diederik_Gr @Dark_wizzie
I appreciate all your inputs but you guys are confusing me even more.
You contradict each other and are throwing around numbers and terms which to me sound like I'd need a PhD :unsure:
So am I correct to understand that the headset which I've set my eyes on is a good pick in combination with my onboard soundcard and it should make listening to music more enjoyable for me?
Yea, I thought we'd separate facts from fiction first, but forgot to get back to your original question.
Well, first, HD650 isn't a headset, because it doesn't have an integrated mic. It's a headphone, and a good one at that.
But, HD650 got somewhat 'specialized' sound signature, or color, if you will. It's not for everybody, some might love it to death, others might not. I'm one of the latter. I can say it's good, but not my cup of tea. Best thing is to try before you buy. If you're buying online, try to find a site where you can return if you don't like it, like amazon.
As for the onboard, it's case per case. There's a big chance your onboard will be fine, but there's also a chance that it will fall behind. Best is to get the headphone first, and take a listen. If it doesn't get loud enough, clipping left and right, distorting, etc, then consider getting an amp, or dac/amp. One thing for sure, it's not too late to get the headphone first, and get the extra later, if needed. Even if the onboard falls behind, it won't do any damage at all.
