So I've heard countless times to not use a vacuum to clean your PC components because it can potentially build up a lot of static electricity and break all your component, but it is okay if you use the vacuum from a distance of about a foot away? My PC is in quite a confined area and I use a can of compressed air to blow out the dust and then my vacuum hose is sitting there, one foot away to suck in all the dust. Is this dangerous for my computer? I have used this method for about three cleans now and I don't see any problems but I just want to make sure. Any help would be appreciated. Thanks!
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/
It's highly not recommended, and I wouldn't advise it, but it technically does work (as long as the dust doesn't take the computer with it through static electricity).
I wouldn't, but it technically does work.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777394
Or maybe a leaf blower
Right. And blow the capacitors right off.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777414
My backpack leaf blower works great. dont give it any throttle and it throws a lot more air at a lower PSI then my air compressor.
Sure, but in the wrong hands it could do a ton of damage to a pc.
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777432
If you're going to use a vacuum, get an anti-static vacuum. Don't you dare use a regular house vac, or I will find you.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777433
you should take it outside and use a vacum that blows like a shopvac or a air compressor
Vacuums, by definition, only suck, not blow.
Compressed air canisters are the best, and fairly cheap, option.
Interested in Linux, SteamOS and Open-source applications? Go here
Gaming Rig - CPU: i5 3570k @ Stock | GPU: EVGA Geforce 560Ti 448 Core Classified Ultra | RAM: Mushkin Enhanced Blackline 8GB DDR3 1600 | SSD: Crucial M4 128GB | HDD: 3TB Seagate Barracuda, 1TB WD Caviar Black, 1TB Seagate Barracuda | Case: Antec Lanboy Air | KB: Corsair Vengeance K70 Cherry MX Blue | Mouse: Corsair Vengeance M95 | Headset: Steelseries Siberia V2
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777444
absolutely nothing will happen. i'm doing that since over 8 years now. as longs as you are on a barefoot and your foot is on solid ground, nothing can and wont happen.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777451
Use a compressed air duster like these:
http://www.amazon.com/b?node=3012916011
SimRacer - Casual FSX Pilot!
Mobo: MSI B550 Tomahawk | CPU: Ryzen R5 3600 | GPU: Vega 64 Sapphire Nitro | RAM: 16GB Crucial Ballistix DDR4 3200Mhz | PSU: EVGA P2 1000W 80Plus Platinum | Storage: 256GB Samsung 840 Pro SSD - 1TB WD Black - 2TB Seagate HDD | Cooling: Dark Rock Pro 3, Noiseblocker eLoop Fans | Case: Phanteks Enthoo Luxe | Audio: Sennheiser HD598 - JBL LSR305s | Display: BenQ EX3501R, Asus VG278H
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777452
Shop vacs can do either.
Dubs are better than subs
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777454
anything in the wrong hands can cause a ton of damage. IE a car, yet we let almost anyone drive those.
OP, if you use a leaf blower do not give it any throttle. I used that alongside with a spare toothbrush to clean everything off
a leaf blower would work fine..just watch the fans ..don't want them to spin to fast
unplug your fans. When they spin they generate electricity. wierd amount of  electricity+motherboard dont mix, let alone damage to the fan
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777455
Which is why government insists we have licenses for some reason to prove we're actually competent. Or something like that. :D
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777470
but...but...but... what if
I already did?
BRRRT!
PC
  • Corsair TX750M
Sim Equipment
  • TrackIR 4
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777497
I already did?
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777520
I already did?
as i said, nothing will happen
PCPartPicker
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777536
Well they have to exhaust the air they suck in by blowing it out, typically through a filtered vent, though with shopvacs they have two holes, one of which is where air gets sucked in, the other of which is where the air is blown out after being sucked through a filter (if there is one in the shopvac)
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777561
Or a bike tire inflator, one that you pump like this:
http://ep.yimg.com/ay/yhst-64576602297917/sportime-double-action-hand-pump-1450708-physical-education-ball-pumps-inflators-9.gif
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4777601
Just use anything that you have around that can blow air. When  I was moving my system into another case, I used a pair of bellows to blow the air away, but I also considered using a bike pump, basketball pump, or electric air mattress pump. Just keep your fans steady while doing anything.
._.
AMD A8-5500•••ASUS GTX 660•••MSI MS-7778 Mobo•••2x4GB DDR3 RAM•••CoolerMaster v550 Semi-Modular PSU•••1.5TB HDD•256GB Samsung 850 Evo SSD•••Optical Drive•••Phanteks Enthoo Pro
https://linustechtips.com/topic/351372-pc-cleaning-with-vacuum/#findComment-4778379
