Please help me with my First PC Build
Solved by ObilvionNizer,
I am building my First PC for my work and gaming. Here's the part list http://pcpartpicker.com/p/9j4PLk
This PC will mostly be used for 3D Animation/Rendering, Video editing, Graphic work and etc and also for some gaming. I would have used Firepro or Quadro GPU but they are out of my budget right now and also i won't be able to play games on it so that's why i decided to go with GTX980(will add second GPU in future)
Any suggestion/Feedback?
Build looks good. Why not see if you can get a working quadro or firepro on second hand?
Whats your budget anyway?
