Rajintek has expandability, so you can add your GPU. The H80i can only cool your CPU.
yeah there are plenty of "expandable" AiOs like this one on the market, its nothing special
someone wanting to build a custom loop should invest in proper quality components instead of cheaping out and buying stuff like this
can't decide if normal post,
or advertisement
Like what?
Like what?
like a WC kit from EKWB or XSPC or alphacool
they do cost a few hundred $ but they are much higher quality and made to last
Like what?
H220X,H240X, and H140X from swiftech is expandable with a powerful pump and res. Fractal Design makes the T12, S24, S36 which use standard G1/4 fittings from Alphacool. Also the Fractal has a pump for new wc users which will not be harmed by dry running, which is where a lot of new wc people make a mistake.
It is in between.
