Hey,
I recently ordered the parts to build my pc. When opening and looking through my NVIDIA GTX 970 manual, it requires a minimum of 500W power supply for the whole system. I bought two of these cards and intend to run them in SLI. PCPartPicker estimates I will need about 550W, yet when I spoke with NVIDIA's customer support they recommended 700-800W. I currently have a Corsair RM 650. How much power will I need overall? Thanks!
Build:
  • CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor
  • CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler
  • Motherboard: Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard
  • Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory
  • Storage: Crucial MX100 512GB 2.5" Solid State Drive
  • Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
  • Video Card: NVIDIA GeForce GTX 970 4GB Video Card (2-Way SLI)
  • Case: Phanteks Enthoo Pro ATX Full Tower Case
  • Power Supply: Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply
  • Operating System: Microsoft Windows 8.1 (OEM) (64-bit)
  • Monitor: BenQ GW2765HT 60Hz 27.0" Monitor
https://linustechtips.com/topic/283542-how-much-power-do-i-need-please-help/
Your current psu is fine. Psu recommendations are often inflated to cover their butts.
650W will be enough, but maybe get a 750 just the PSU is more chilled
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
I dont have an answer but i can tell you if you put all your parts into pcpartpicker it will tell you how many watts u need
 The Wannabe is no longer. Replaced by the Flotilla. If you replace every part of a computer is it still the same computer?
Survived the Survivor 2299
Audio Engineer, Lighting Programmer, Video Engineer, FOH.
A 500w pus would be fine, but a tiny bit iffy. 650w is plenty for triple 970s if you want an upgrade. The 970 really doesn't use that much power, generally less than 170w under load.
Nvidia customer support is more accurate, remember that you are not aim for your psu to have just enough power, you want it to run around 60% for peak efficiency.
No they are not... They over estimate. 650is more than enough
650 is actually good enough , unless you want to upgrade to a platinum grade for anywhat difference you need to make, reason is that regardless the TDP the system recommendation says it should have , real world performance your system (your setup) is actually pulling less tan 500-550 watts max from the wall at the peak performance so the more power labeled ones are actually useless for your build except looking mighty cool & it has been tested, Hope this helps you out..
Details separate people.
