For Some of us High speed camera means 120fps to 240 fps on our smart phones & those who are used to professional camera maybe 1000 fps to 6000fps & even more enthusiastics it can heave upto 10,000fps & even going further it can come to 100,000 fps to the max!!
Guess what?.. Scientist have developed technique where a single-shot compressed ultrafast photography is taken at one hundred billion frames per second That is 100000000000 fps.
The Technique is called compressed ultrafast photography (CUP) & it's a two-dimensional dynamic imaging technique,
Don't Blink..
The Camera is , as you guessed is not an ordinary camera but a specialy designed industrial strength high-speed camera.The Purpose for the camera build is for to track light as it travels and interacts with objects , so nor regular time warp application :/
CUP technique could be used in the development of so-called invisibility cloaks
Researchers used the technique to explore phenomenas such as how light reflects and refracts, as well as how photons behave when transitioning from one medium to another
One of the purposes for the build is to Study Invisibility Cloaks, you heard that right , The camera is  so fast that it can actually capture light in it's path (in 2d) what they plan to do with t the technology is to study how light intereacts & behaves on & around certain object , by learning that they can research into light interactive fabric that can behave that can bend around fabric making the object literally invisible to the naked eye..
Soon this could be a reality..
"This field of study, popularized in Star Trek, is real, and although may advances are being made in fundamental approaches to cloaking designs, the inability to see the interactions between light and the object being cloaked hampers development,"
CUP System Configuration: camera setup
Previous well advanced cameras could only record at roughly a billion frames a second
Explanation of the image above:
With CUP, the photons necessary to take an image are blasted through a beam splitter and then through a tube that has several tiny mirrors. These photons are converted into electrons, which encode the data you want captured namely the time and space data necessary to create an image. All of this happens in one billionth of a second, and the data can then be arranged into a video on a computer
Strictly speaking this is not the fastest camera in the world still..the fastest in the world as of now can capture images upto trillionth frames per second that camera was able to capture stunning picture of heat conduction, but that had so many limitations unlike this one.
Screen-shot-2010-08-19-at-4.59.04-PM-580
if only it could capture images in this 3d format :/
The technology is impressive and quite complex. Previous cameras could record at roughly a billion frames a second, but could only do so in one dimension that meant you could measure space or time, but not both. And it was slower, anyway.
To be totally honest, we're not even sure what we'll be able to see with a camera this fast.
Compared with existing ultrafast imaging techniques, CUP has the prominent advantage of measuring an x–y–t (x, y, spatial coordinates & t is time) scene with a single camera snapshot, thereby allowing observation of transient events with temporal resolution as tens of picoseconds. Furthermore, akin to traditional photography, CUP is receive-only, and so does not need the specialized active illumination required by other single-shot ultrafast images
Captured ultra fast image of a laser beam shot into different medium:
By the way PS equals picoseconds ie One trillionth (10^-12) of a second.
Expalnation:
Figure A:  laser beam light reflecting/bouncing from the mirror (the mirror is drawn into the image to show the placement)
Figure B  shows the beam going through different medium(refracting) air into clear resin.
Figure C shows Difference in travel speed between the laser beam in different mediums ..(racing)
Video demo for figure A: (mirror reflection)
Video for the Figure B: (Air to clear resin)
Akin to traditional photography, CUP is receive-only, and so does not need the specialized active illumination required by other single-shot ultrafast imagers As a result, CUP can image a variety of luminescent such as fluorescent or bioluminescent objects
Given CUP’s capability, The team expect to find widespread applications in both fundamental and applied sciences, including biomedical research.
Pretty cool  stuff, Would be cool to see how the technology is implied, pretty interesting...What are your Thoughts/opinions on this? Post your comments down below for us to read..
Bonus:
News Link:
http://www.engadget.com/2014/12/04/high-speed-camera-tracks-light-at-100-billion-fps/
http://motherboard.vice.com/read/the-fastest-camera-ever-created-will-be-used-to-study-invisibility-cloaks
Original Article/Report:
http://www.nature.com/nature/journal/v516/n7529/full/nature14005.html
Details separate people.
Frames per second is just a number
I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar
I question your mother's upbringing if you don't like me - Action Bronson
You apocalyptic dingleberry - James 'Captain Slow' May
#ubisoft #keepondigging #neverforget
Yes, I quoted myself
This looks really neat though. All the pictures look very science-y, I'm sure this will work perfectly.
This is stupid.
A more cinematic 24fps would be a lot better.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
Crap,thats a lot of frames per second. But as @ said, "Frames per Second is just a number" It is still cool that scientists have created such a camera. I wonder what the cost would be on such a device.
Ryze of the Phoenix:
CPU:      AMD Ryzen 5 3600 @ 4.15GHz
Ram:      64GB Corsair Vengeance LPX DDR4 @ 3200Mhz (Samsung B-Die & Nanya Technology)
GPU:      MSI RTX 3060 12GB Aero ITX
Storage: Crucial P3 1TB NVMe Gen 4 SSD, 1TB Crucial MX500, Spinning Rust (7TB Internal, 16TB External - All in-use),
PSU:      Cooler Master MWE Gold 750w V2 PSU (Thanks LTT PSU Tier List)
Cooler:   BeQuite! Prue Rock 2 Black Edition
Case:     ThermalTake Versa J22 TG
Passmark 10 Score: 6096.4         CPU-z Score: 4189 MT         Unigine Valley (DX11 @1080p Ultra): 5145         CryEngine Neon Noir (1080p Ultra): 9579
Audio Setup:                  Scarlett 2i2, AudioTechnica AT2020 XLR, Mackie CR3 Monitors, Sennheiser HD559 headphones, HyperX Cloud II Headset, KZ ES4 IEM (Cyan)
Laptop:                            MacBook Pro 2017 (Intel i5 7360U, 8GB DDR3, 128GB SSD, 2x Thunderbolt 3 Ports - No Touch Bar) Catalina & Boot Camp Win10 Pro
Primary Phone:               Xiaomi Mi 11T Pro 5G 256GB (Snapdragon 888)
Crap,thats a lot of frames per second. But as @AlexStrizenec Ubisoft said, "Frames per Second is just a number" It is still cool that scientists have created such a camera. I wonder what the cost would be on such a device.
Fixed.
But I agree though. I think this is one of those times when the scientists are just flexing their hypothetical muscles and saying "hey, look what we can do". Still fucking cool though. And I want my damn invisibility cloak now.
For fox sake its LASER not lazer
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
It's FUCK'S not fox
It's FUCK'S not fox
You are reported for profanity.
Nah, j/k
60FPS Microwave
Laser is like a lesser form of lazer. Lazer is just a better spelling.
The stone cannot know why the chisel cleaves it; the iron cannot know why the fire scorches it. When thy life is cleft and scorched, when death and despair leap at thee, beat not thy breast and curse thy evil fate, but thank the Builder for the trials that shape thee.
don't they already have camera that can do 1 trillion frames per second?
I think they called it femto photography.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
LASER
Light
Amplification through
Stimulation of
Electromagnetic
Radiation
I can most assuredly guarantee you its LASER.
Anyway after reading everything I'm impressed by the tech but sad its only a 2D technique, I was looking forward to seeing Jamie and Adam recording explosions at 1000000000000 FPS.
Main Rig:-
Server:-
LASER
Light
Stimulation of
Electromagnetic
Radiation
Sorry, but it's "stimulated emission of radiation" not "stimulation of electromagnetic radiation".
What the fuck? Ok you've just blown my mind. There is already a "lesser" form of laser. Its called an LED. All you need is a resonant cavity to turn it into a laser, theoretically.
Seriously, lazer is for kids. This spelling is just dumb
60FPS Microwave
wait so 1 second of recorded footage, played back at 30fps is 6431 years of footage
hmm
This is stupid.
Did somebody forget their sarcasm sticker?  :lol:
I run my browser through NSA ports to make their illegal jobs easier. :P
If it's not broken, take it apart and fix it.
http://pcpartpicker.com/b/fGM8TW
hmm
hmmm seems about right yeah, altough i doubt they will make recordings wich are longer then 0.01second, because light and stuff, ya know photon detection orsomething like that(completely lost track of words)
May the light have your back and your ISO low.
Yeah but imagine scrubbing through the timeline to find when the light hit
i think that might be pretty visable, if they see roughly the same thing as in the pics of OP, then there is a clear diffrence between the tracked object(in this case a laser/lazer beam/shot) and non tracked object(mirrors/walls) since the system probarlly uses heat mapping it's easier to see then a normal type of view.
