So the new model of the raspberry got released! It's really cool what they can make for so little money, I'll probably get one to play with :)
Model A+ Specs:A+_Overhead-300x199.jpg
Dimensions: 65x56x12mm
Memory: 256MB RAM
Expansion: Micro SD slot,
1x USB, 40x GPIO
Networking: None
Price: ~$20/£15
The freshly updated version of the Model A does much more than simply bring it in line with the Raspberry Pi Model B+ released in the summer.
The Raspberry Pi Model A+ is the same dimensions as a HAT (Hardware Attached on Top) add-on board, the same price as two cinema tickets and can run at nearly half the power consumption as the Model B+.
The 3.5mm audio & composite jack means the Model A+ stands nearly half the height of the Model B+
According to Eben Upton, Founder of the Raspberry Pi Foundation, the new $20 price of the A+ is really pushing the envelope of what’s possible.
Since it uses the same improved power chain as the Model B+, the Model A+ consumes much less power than any other Raspberry Pi. According to its designer, James Adams, running the same ‘hello_teapot’ demo with a USB keyboard and a HDMI monitor connected the Model B+ consumes 370mA, while the A+ consumes just 200mA – 45% less power under the same conditions.
Source: http://www.raspi.today/raspberry-pi-model-a-plus-out-now/
// TODO: Update signature to include PC buid.
https://linustechtips.com/topic/248051-raspberry-pi-model-a-out-now/
But can it run crysis?
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
Wow i kinda want one but its got no networking :/ maybe i could use a usb hub with a usb wifi adapter?
Yeah, that's what I noticed too. That will probably work. I guess someone will make a networking shield for it which you connect with the GPIO pins.
Yeah it's impressive and all but I think it's about time we get a performance upgrade.
I know the Raspberry Pi is not suppose to be a beast in terms of hardware, but surely the price:performance ratio on ARM processors must have gone up in the last 2-3 years. The price on the other models (A+ is 5 dollars cheaper) have stayed the same and I would have liked to see for example a slight CPU or GPU upgrade.
Perhaps that would break compatibility with existing stuff and that's why they are reluctant to upgrade it.
Yes that will work, or you could use wireless. At that point you might as well just get the B model though, which has Ethernet built in. Would probably end up costing the same but you get more RAM and a more elegant package (no extra wires and boxes needed).
Have to agree. Was disappointed when I heard there wouldn't be a performance upgrade.
im still confused why the guys who started raspberry went with a ARM11 soc
an ARM A8 with a mail 400 was just   a dollar or two more expensive and around 3 times faster
its just really slow
i hop wayland and the opensource driver fixes things
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
Yeah it's impressive and all but I think it's about time we get a performance upgrade. I know the Raspberry Pi is not suppose to be a beast in terms of hardware, but surely the price:performance ratio on ARM processors must have gone up in the last 2-3 years. The price on the other models (A+ is 5 dollars cheaper) have stayed the same and I would have liked to see for example a slight CPU or GPU upgrade. Perhaps that would break compatibility with existing stuff and that's why they are reluctant to upgrade it. Yes that will work, or you could use wireless. At that point you might as well just get the B model though, which has Ethernet built in. Would probably end up costing the same but you get more RAM and a more elegant package (no extra wires and boxes needed).
I own the B+, and I am enjoying the programming experience with it. With that said, my nerdgasm when it comes to the Pi, is having a massive array of Compute Unit SODIMMs inside a regular ATX chassis and using a 500W PSU. Then it would be ARM multi-threading galore.
This is where a specs upgrade be of serious benefit.
Read the community standards; it's like a guide on how to not be a moron.
Gerdauf's Law: Each and every human being, without exception, is the direct carbon copy of the types of people that he/she bitterly opposes.
Remember, calling facts opinions does not ever make the facts opinions, no matter what nonsense you pull.
No ethernet = no cares.
Lack of integrated networking severely limits its potential uses. I know the goal is to make it more compact, but killing the ethernet port doesn't make much sense.
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
The only problem I have is coming up with a purpose. I'm not saying there is non jus that I don't have any ideas, input is welcome though ☺
First purpose which comes up in me, is using it in a robot as integrated computer or something. A robot doesnt need networking or something!
I have another idea for this too, but I'll post about that later, when it's done :3
They should release ethernet version because in some uses ethernet is a must and in some it's stupid to have.
The A model has never had Ethernet so they haven't really removed it. The Model B got updated a while ago (biggest change was 2 more USB ports) and now it's time for the model A to get updated.
I want to say "I guess there is no reason to get the Model A anymore" but to be honest there was never really any point in getting that to begin with (for 99% of everyone getting a Raspberry Pi). 15 dollars for twice the RAM (512MB compared to 256MB), 3 more USB ports (4 vs 1) and Ethernet is definitely worth it.
That's what the Model B is for.
There are always reasons to get a Model A. This tiny one is ideal for embedded projects, you can integrate it and leave it there. It's a cheap and easy solution :)
Now we need a model C , With 2G of ram and a updated SoC with ARM v9 or v8 gigabits Ethernet and a Sata II or III (Or would it be Esata?) port.
A riddle wrapped in an enigma , shot to the moon and made in China
But what's the point of having an embedded system without networking? There are probably some scenarios for the Model A but I can't think of any for average consumers. The price difference is just too small and the difference too big.
I own the B+, and I am enjoying the programming experience with it. With that said, my nerdgasm when it comes to the Pi, is having a massive array of Compute Unit SODIMMs inside a regular ATX chassis and using a 500W PSU. Then it would be ARM multi-threading galore.This is where a specs upgrade be of serious benefit.
I can't wait to get my hands on one. In the meantime I'm still learning more C++ and working on problems from project euler.
Tea, Metal, and poorly written code.
Ben Heck's Portable Pi handheld gaming system... He built that with a Model B then had retrospect that should have gone with the Model A so he wouldn't have had to unsolder and remove the Ethernet.
Building a new version of the Portable Pi with the Model A+ would make more sense now than with a B or B+ since there's no need to remove the Ethernet to slim it down, and the single USB port can be removed and hand-wired into a small hub for whatever reason you might have (such as adding a wireless keyboard/trackpad dongle whilst also having built-in joysticks).
Heck, build the Portable Pi with the GPIO serving the joystick/d-pad/face buttons and leave the USB port for plugging in a keyboard or something when needed.
Damn you, I'm doing something like this aswell hahahaha
