The OS itself will fit on the ssd yes, but no programs will. Which makes the SSD idea meaningless. Just having the OS on an ssd will not make your PC feel noticeably faster.
Either get a harddrive, or save a few extra dollars and get a 128 gig minimum (enough for OS + vital programs + vital games).
https://linustechtips.com/topic/239462-small-ssds/#findComment-3283681
Save up some money to buy a bigger SSD. Managing an OS on a tiny SSD is a pain in the ass. My first SSD was a 60gb, and I quickly regretted not buying a bigger one.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/239462-small-ssds/#findComment-3283683
i have a very very slim budget on a ssd would i be able to get away with a 32gb ssd for windows 8.1 and all the updates?
Considering that a 64GB is only a few more bucks then a 32GB (last time I checked the difference between them was 70 cents), no. Don't get a 32GB SSD.
Get at least a 60/64GB. However for you to actually feel comfortable with the space that you have a 120GB is recommended.
"Rawr XD"
https://linustechtips.com/topic/239462-small-ssds/#findComment-3283684
Could you list your total budget and the other specs you're thinking about getting? Maybe we can help figure out something...
If you're thinking of getting a 32 GB SSD and a 1 TB HDD, it may be a better idea to forgo one of those and buy it later.. Maybe start with just a 120 GB SSD alone and add the 1 TB HDD later, if you can live without all the extra storage for a little while..
i7 not perfectly stable at 4.4.. #firstworldproblems
https://linustechtips.com/topic/239462-small-ssds/#findComment-3283689
There is no point of having an SSD that small for only your OS. Save up some money for a 120 or 240GB SSD to put your programs on.
https://linustechtips.com/topic/239462-small-ssds/#findComment-3283745
my install / program data / user profile is 90+gb - If I really tried to tidy this I could slim down maybe 10gb... but that's all... many applications install data on the OS drive even when they are primarily installed on a secondary drive.  I would go 128gb, 64gb would be an issue and 32gb would be a pain.
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
https://linustechtips.com/topic/239462-small-ssds/#findComment-3284530
