Corsair H110 problems need help...
Solved by LemonSpice,
so this post is solved. i dropped my h110 down while figuring out the cables^^ my pump just broke off. i am so done. now going with stock cooler and waiting for a cheap aircooler.. however you guys are awesome you all gave your very best to help me! a great community i am going to recommend:)
one last question is a heavy aircooler going to damage anything due to his weight?
sorry to hear that but as long as you are not shipping it anywhere or banging it around a lot a heavy air cooler should not damage anything.
