I've noticed on a lot of cars, there's some weird positions on the gear shifter, such as this for example:
P-R-N-D-3-2-1-L-B
What exactly are the last 5 for? I know what P-R-N-D is and why they are in that order, but I don't get the rest, especially the L and B. What are they for?
https://linustechtips.com/topic/212378-car-question/
1 is first gear
2 is second gear
3 is 3rd gear
No idea what L or B are, never heard of those. On an automatic the gearings can be useful for saving your breaks when you go down hill. D or Drive is simply 1 through 3, but controlled by the car (and how hard and fast you hit the gas pedal)
Dubs are better than subs
https://linustechtips.com/topic/212378-car-question/#findComment-2883864
P-R-N-D-3-2-1-L-B
These aren't all present on one shifter. 1, L, and B won't be found on one shifter
3-2-1 mean that that number is the highest gear the tranny will shift to. So if you don't want the car to shift higher then 3rd you put it into 3. The car will still use first and second gear when in 3 though, it just won't go into fourth. 1 locks it into first gear
L is the same thing as 1 on regular transmission vehicles, on a gasoline CVT it puts it into a lower gear-state, to make more effective use of engine braking or crawling. On a Hybrid, in L, the electric motor is used to create resistance to slow down the car without using the actual brake pads
B the same thing as L but on Toyota hybrid vehicles
"Rawr XD"
https://linustechtips.com/topic/212378-car-question/#findComment-2883873
Maybe it's some wierd form of automatic?
P is Park
R is Rear
N is Neutral
D is Drive
1/2/3 is probably 1st, 2nd and 3rd
L may be low (at least on my mom's car), wich is used for going up/down hills
No idea what B means.
i'm a potato
https://linustechtips.com/topic/212378-car-question/#findComment-2883881
Thanks for all the replies, on my dad's two cars it goes something like this:
Mercedes ML-500 (2004)         Acura TSX (2010)
    P                                                        P
    R                                                        R
    N                                                        N
   -D+                                                      D
                                                               S
Does anyone have any experience using Sports mode on an automatic to manually shift? How does it work?
https://linustechtips.com/topic/212378-car-question/#findComment-2883909
    P                                                        P
    R                                                        R
    N                                                        N
   -D+                                                      D
                                                               S
it's tiptronic drive, it bypasses the ECU automatic shifting (to a degree, it will still downshift at low speeds or deny upshifting at very slow speeds)
In some cars it may modify performance and throttle response (feels like it does on mine, and I know for sure the throttle reacts differently), but the main benefit is allowing you to choose when to shift.
it's also very useful for driving in hilly areas.
Error: 410
https://linustechtips.com/topic/212378-car-question/#findComment-2883936
Both of my cars look like this:
1 3 5
   N
2 4 R
Lol, It looks like your question has been answered so I thought I'd have a bit of fun ;)
https://linustechtips.com/topic/212378-car-question/#findComment-2883971
1 3 5
   N
2 4 R
manual master race
I'd drive manual (I was talking about this w/ @TheSLSAMG) but since I live in NYC of all places manual driving in traffic would probably cause me to go and smash somebody's monitor to bits, so I'm kind of forced to drive automatic.
https://linustechtips.com/topic/212378-car-question/#findComment-2883979
manual master race
Yeah I hear you. Manual's really suck in traffic. I still really like them, but in Fargo there isn't a lot of traffic, so I can get away with it. The next car I plan to buy is also a manual, I'm not ready to give it up.
https://linustechtips.com/topic/212378-car-question/#findComment-2884003
    P                                                        P
    R                                                        R
    N                                                        N
   -D+                                                      D
                                                               S
Depends on transmission.
In the -D+ it means that you can move the shift lever left and right to "manually" shift gears, by telling the tranny when to shift up/down when you want it to rather then the computer. On some cars this means that when you move the lever to + the car WILL upshift when you do so (my Nissan Maxima did this), however on some cars, the - + shift gate is just an extension of the 3-2-1, like on my current Camry. If you're in 3 and press + to go to 4, the car won't do it right away, it will just unlock 4th gear and shift to it when the computer feels like it. All depends on the car
If you have paddle shifters then S will activate them. If you don't, then it will likely just put the tranny into "Sport" mode which just makes the car rev higher before automatically upshifting
"Rawr XD"
https://linustechtips.com/topic/212378-car-question/#findComment-2884036
time to shed some light, B is for regenerative  braking, toyota prius have these.
my friend drives a baby blue prius.I didnt learn about that until about a week ago
Like I said, it's been in all Toyota hybrids ever since they started. My Camry HV has it, brother's Highlander HV has it, dad's Prius has it
"Rawr XD"
https://linustechtips.com/topic/212378-car-question/#findComment-2884049
-snip-
My dad told me about the -D+ and said he wouldn't do it to protect the transmission, and he likes driving full automatic even though he can drive a manual.
OT: I love how on trains the shifter is literally inserting a fucking wrench with three positions F-N-R (R can get ops in trouble w/ RTO) and on the latest & *cough*not the*cough* greatest trains it's a keyhole with OFF, RUN, and SP CHG with a knob below that says FWD-NEU-REV.
https://linustechtips.com/topic/212378-car-question/#findComment-2884133
It won't damage the transmission. The computer prevents you from doing anything stupid. And it's not like you're forcing the gears with a clutch like on a manual, you're basically telling the computer when you want it to shift. It's still an automatic, since really all you're doing is pressing buttons.
"Rawr XD"
https://linustechtips.com/topic/212378-car-question/#findComment-2884256
This is the only automatic I will accept:
Audi Tiptronic.
post-37262-0-76576300-1410313142_thumb.j
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/212378-car-question/#findComment-2884385
i have driven both automatics and manual cars, i realy prefer manual. :D
L - i think this is for low gearing, "probably" for in the mountains with caravan.
B - maybe Bad weather for snow or something idk. :P
B is the same thing as L but in Toyota hybrids. For increased engine braking (in this case electric motor braking)
"Rawr XD"
https://linustechtips.com/topic/212378-car-question/#findComment-2885198
No paddles?
Nope, no paddles.
https://linustechtips.com/topic/212378-car-question/#findComment-2886642
So on automatic transmitions, if you're towing a load, like in my truck, you'll want to manually select the gear to keep the motor in the power band longer than the transmition normally would if you were to be driving down the road, especially going up or down a hill. The transmition in question seems to be a 4 speed auto, so 3 is third, 2 is second, 1st is first, L is for low, and it seems that B would be a sort of parking brake if I had to guess.
Only if your vehicle sucks at keeping it shifted in to the power band. I know our old Silverado kept switching between third and fourth gear when we were towing because the gearing sucked and so did the shift times on the computer.
https://linustechtips.com/topic/212378-car-question/#findComment-2886656
P-R-N-D-3-2-1-L-B
Google is your friend
http://www.hybridcars.com/forums/showthread.php?99310-What-does-the-B-mean
https://linustechtips.com/topic/212378-car-question/#findComment-2886681
