It can. If the electricity goes off often get UPS.
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2678251
It should work fine for a long time. Only parts that don't like power interrupted are hard drives and shitty psu's.
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2678294
It won't damage any parts (aka kill your pc) but it can corrupt your OS in which case you would need to reinstall windows.
If you have frequent power outages buy a UPS. This is a battery backup power that will run your PC for a couple minutes and tell it to shut down properly in the couple minutes it remains on after power is lost.
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2678318
You sure? or are you insane.......
It's not good for it but it should be fine. I have to unplug my 24 pin for the PC to start after a power outage and my bios settings get all messed up. But if you can't do anything about it, I wouldn't worry too much. Not going to break stuff hardware wise but could mess up some bios settings and lose your work. (If it is not saved)
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2678336
Not sure if it was because of this, but I used to live (moved now to another) old house, but the powerlines were really old and quite unstable. Result: PSU + mobo destroyed somehow (Medion pc, not the greatest quality). Had to send it in for 2 weeks. I believe they said that the PSU short circuited the mobo. Not sure if that's possible though.
It is said, that civilised man seeks out good and intelligent company, so that through learned discourse he may rise above the savage and closer to God. Personally, however, I like to start the day with a total dickhead to remind me I'm best!
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2678923
why would you do this tho? just turn your pc off the way its meant to be turned off and thats that? usually i never even turn my pc off unless im off on vacation, other than that its on or sleeping.
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2678931
Most dangers of a power loss is the just the power loss but if its a quick intermittent power loss followed by a power on, worse if its happens more than for one cycle. Think of it as someone playing with the light switch but at a much faster rate.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2679084
It's not the off, it's the on. Surges kill psu's. Think lightning. Now if you're turning the power off from the wall and it's not surging back on, not quite so damaging but not good for Windows. It will bitch and complain for good reason. You should always have the machine powered down before cutting the power. Now if the machine is off, then go right ahead. It won't affect a thing.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2681943
It shouldn't damage anything. I've had to slam on the power switch on the splitter cable thingy that i've plugged my pc into during massive thunderstorms before and it hasn't been damaged yet.
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2682024
I want to know if my PC might get damaged of DIE!, if I shut it down by switching off the power from the walls.....(actually electricity goes off more often here...).
Before seeing your location I was almost certain that you were in egypt :3 it cuts here 6 times for 1 hour per time -_-
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2685098
I feel like this is a Troll post... Why would you even ask, answer is always going to be yes. Your components will start to die out slowly :(
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2686428
I think he really didn't know, you'd be surprised at how many people aren't tech savvy
The most common result of insufficient wattage is a paperweight that looks like a PC
https://linustechtips.com/topic/197492-will-my-pc-dieif/#findComment-2686468
