Questions about headphones and dac/amp
1 hour ago, Allena said:This is what I think is complicated, dac and amplifier.
Nah, DAC and (headphone) amplifier are the simplest components that have become snake oil. Like charging $1000 for a $5 HDMI cable.
All "soundcards" are a DAC/amp. All headphone ports are connected to a DAC/amp. The DAC converts the digital signal into an analog signal. You can't hear 1's and 0's. The amplifier then brings that analog signal to a listenable volume.
If you're in the USA, then the $9 Apple USB-C (or Lightning) to headphone dongle (DAC/amp) is the best audiophile product ever made.
1 hour ago, Allena said:do I need one with built in virtual sound, or can I use software for that?
Absolutely not. Virtual surround is a gimmick. An unaltered stereo track is all that should be used.
1 hour ago, Allena said:Does anyone have any recommendations for headphones and dac/amps?
It depends on what you need the DAC/amp to do. I think the best reason to have a DAC/amp is to have a volume knob.
- I use the Apple dongle for my main setup because I wear earbuds/headphones.
- The Schiit Magni is an incredible headphone amplifier deal at $59. It has RCA outputs for controlling speaker volume. Use your Desktop PC's Line Out from the rear.
https://www.schiit.com/products/magni-plus
- JDS Labs sells Atom Amp+ and Atom Amp 2 if you want more power (you don't). It has 2 inputs if you need it. Nicer box/construction.
https://jdslabs.com/product/atom-amp-2/
- FiiO K11 is a gorgeous newish DAC/amp. USB input to the computer. Or if your TV is your main display and all of your devices are routed through it, then you can use the optical output from the TV to the K11's input.
https://www.amazon.com/FiiO-K11-Headphone-Amplifier-Balanced/dp/B0CJFG3DC7/
