Help me pick a gpu for my ryzen 7 5800x
so i am looking to buy a new gpu
im not very educated on them so i don't know what im looking for
my budget is around 600-750 euro's
what gpu will be a good fit with my  cpu?
What resolution? Are you gaming or other? What programs/games will you use? If it’s 1440p a 4070 or 7800 xt should be great. Maybe even for 1080p
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
16 minutes ago, Shimejii said:
Would not go above a 4070 / 7900GRE . You would have to upgrade the CPU to get much more performance.
GT 730 is an obvious choice,
but perhaps 7800 XT if we want to play recent games and some that haven't been released yet..
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
so i just game at 1080p i mostly game only and i play  games like resident evil,gta,fortnite,
is there a big difference between a 4070 or 7800 xt
i also had one person say the 7900 would be good
7800 xt has more vram
You’d probably get a cpu botteneck but the 7800 xt should be a good option
Current parts list
With those games at 1080p, anything more than maybe a 4070 ti super or whatever is is a waste.
Really, my GTX 980 ti can do fine in those games.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
do you plan on upgrading the display to 1440p anytime soon?
PC:
PCs I used before:
no not really 1080 is enough for me honestly
so it really depends how often you upgrade and how long you want it to last, on 1080p it's not gonna require as much VRAM as a 1440p or 4K would in the future, though,
so like a 7800 XT I guess would be plenty, it's slightly faster than 4070 but should also be cheaper,
you'd only want Nvidia if you want Nvidia features or RT performance, which is what comes with the increased price, AMD can also RT if the settings aren't too high or the RT isn't demanding, RT off is where AMD can be cheaper and on par or slightly better, depending on which cards are we comparing
also don't forget good PSU unless you already have one
PC:
PCs I used before:
On 4/18/2024 at 2:39 AM, Peacheling said:
...my budget is around 600-750 euro's...
At that price range, the good options are going to be bottlenecked by your CPU. You might get 200fps instead of 250fps.
Can your monitor show 250 or even 200fps? Is it the end of the world?
Anyway, I recommend the 7900 GRE. See this video at 08:15 of what it can compete with when the memory is overclocked. Check the price of those GPUs it competes with
When you finally upgrade to 1440p, it becomes a 4070Ti, and at 4K it becomes a 4070Ti Super
