This is a long one.
So I live in an apartment that is quite long, and due to some reasons, the router has to be in one end of the house.
This means that on the other end of the apartment, the wifi signal barely reaches. So to fix this, I got a wifi repeater, and I ran an Ethernet cable to that repeater. That fixed the wifi problem.
However, I have another problem. The wifi repeater allows for two Ethernet connections, so one is used to connect the repeater to my router, and the other one is to connect to my PC.
However, the connection to my pc isnt direct, it goes from the repeator>ethernet extension block>pc. So it uses two cables instead of one.
My package is 80MB/s, and with the repeater, it only gives me 10MB/s. Not only that, but I also have a lot of packet loss when playing games.
Is this due to the repeater? Do I have to get a repeater that supports more bandwidth, or would it be better to just buy a second router?
https://linustechtips.com/topic/1566815-i-need-help-with-ethernet/
That slower speeds kinda feels like a 100M link. Check that all the links are gigabit.
What speeds if you plug the main router into your PC directly? You could add a switch between the main router, your PC, and the second Wifi AP.
Yeah, that's likely a cable/adapter issue, I'd make sure they're all gigabit cables. Also another option would be to use a powerline adapter set if you have to use ethernet. Otherwise, if your WiFi is able to deliver your system it's full speeds, just use that.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - Sapphire AMD RX 7900XTX Nitro+ 24GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S24+ - Ceramic White 512GB |
As in the ethernet link to the PC goes through an ethernet coupler?
What type of ethernet cables are you using?
A make/model would be very helpful.
20 hours ago, OddOod said:
Yeah, I'd grab a cheap gigabit switch and not use the one in the AP repeater
This sounds premature, if its a cheap ethernet coupler I'd sooner blame that.  I bought a whole batch and they were so cheaply made I would lose the connection entirely if anyone sneezed near them.
Assuming its just being used to make a longer cable, buying a longer cable so you don't need it is the obvious option.
If it still doesn't work then I would wonder if the repeater in fact has no switch and is running those ports over the CPU.
59 minutes ago, Alex Atkin UK said:
ethernet coupler
Like an unpowered extender? That's just signal integrity loss.
A TPlink 5 port gigabit switch is under 20 bucks and they're ~bulletproof.
Yes, it goes through an ethernet coupler, I didnt know the name
The repeater brand is Aigital, I couldnt find the model.
We cant really buy another longer cable, because its installed into the wall, and taking it out and rerouting it would be a pain.
Also, im pretty sure the repeater doesnt have a switch.
Ive never heard of an ethernet switch before, I will try it and post results
Im pretty sure I bought cat 6 cables, if thats what you mean. And I will try the switch, Ive never seen it before, I will post the results
This is a good overview of hardware components of a network
Well that could be a problem, as damage/bad connections is fairly common when the cable is in the wall.
As for a switch in the repeater, you wont know either way, neither routers/extenders ever advertise the fact they have a switch or not.
