ping spikes I think its an ISP problem but am unsure
CatXice
Hi,
so when playing games i get this micro lag spikes now and again and i have no idea whats causing it my wife has the same problem so it could be a problem on our network but i have no idea how to test for this or if its a problem with my ISP i need help
Theres a 1gb link from ISP router (4years old ish) to my AP everything on my network is WIFI or wired to this AP.
wiring is my AP 1gb cable to my switch which has both PC wired to it this is 2.5gb link between the PC's (steam local downloads are fast AF thats y i have this also there is only 1 cable running up stairs in the house from were the AP is)
my ap is a TP-link AC1750 in AP mode doesnt handle nat the ISP router is dealing with that (my PC is a plex server as well)
when i ping my wifes PC its fine? image.png.fd14beece9947883811d88ae6ed97b2a.png
when i ping my laptop (WIFI not sure y it says 0ms when it should be 1ms) image.png.5a1684f4fd22e1df653d58729ef02976.png
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
You're using wired ethernet, right?
Tried rebooting the router?
F@H
GPD Win 2
ye wired 2.5g between the PC and 1g to the router
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
1 minute ago, CatXice said:
yep 2.5g/1g
what's the router and how old?
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
So there's an additional switch?
F@H
GPD Win 2
theres a 1gb link from ISP router (4years old ish) to my AP everything on my network is WIFI or wired to this AP.
EDIT: added another screenshot to main postimage.png.3c9096f6d6fe0b730e6d251179c85cf9.png
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
Are you monitoring your bandwidth utilization at the same time you see spikes in your ping? Saturation can cause increased latency. So can CPU at 99%, the switch, the AP and the ISP router all have CPU inside of them, it would be hard to monitor them all.
What type your Internet is? DSL, Cable, Fiber?
Can probably connect a laptop to ISP router directly and ping Google all day to see if you have the same spikes.
