To keep side panel on or off?
remo233
So with the side panel on my temps are; gpu 74, vram temp 84-86 and hotspot 88-89
With side panel off: gpu 68-69, vram temp 76-78, hotspot 83
Side panel on. Those GPU temperatures are still within safe limits 🙂
How many fans are in your case?  How are they laid out?   Panel off shouldn't produce temps that different if you have good airflow thru the case.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I have a small case, airflow is not great. I have two fans in the front for intake and one at the top amd back for outtake. When I installed the gpu, there is little space between the bottom of the gpu and bottom of the case parts. The front of my case just has small cuts on the front sides for intake. I believe I need a better case.
what case is it?
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
55 minutes ago, thrasher_565 said:
what case is it?
Corsair CC-9011086-WW Carbide Series 88R Windowed mATX/Mini-ITX Case for Computer - Black https://amzn.eu/d/5oa433f
oh ya thats a ship case... if you want to use a dremal you can try and fix it... but 74c is still not bad of temps could it be better ya like you found out but even realy good air flow case can get good temps drop with the side off so...
Your temps are fine. If they bother you, just leave the side off, try alerting the fan configuration and fan curves, get better fans, or get another case.
That is case dependent, I would say. Don't you think so?
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
I keep the side panel off and AIO radiator outside, nice and cool. Can't say recommended it but still...
GPU is cooler also in this mode.
I edit my posts more often than not
When your gaming computer needs an upgrade. - Imgflip
Lol dude
Case if part of it, but fan config is the other.  it highlights that his case and/or airflow are not that good.
OnePlus:
Other Tech:
Does this chassis allow the removal of the front? What fans do you specifically have installed in the front?
I have two 120 mins fans installed in the front. I can pull the front off but there are wires connected so it cannot be taken off.
What are the specific fans?
