Is inflated/fake TBW a real thing?
MLC has much higher endurance than TLC ... something like 5000 to 8000-10000 erases. TLC has fewer erases, something like 3000 to 6000 was common if my memory is correct.
Older SSD controllers could only use a portion of the Flash memory in pseudo-SLC mode - basically the empty flash memory is converted from TLC into SLC so instead of storing 3 bits into each cell, only one bit is written. The memory in this SLC mode is more tolerant to erases, think of it like 10-15k erases instead of 3-6k erases when in SLC mode. As this SLC area is filled up, the controller takes the data and writes it in background into TLC memory area. Temporary stuff is never written, because the controller only moves the data later, when the system is idle.
The WD Green may use lower bin of Toshiba / Sandisk flash chips, the "standard" quality bin of flash chips they use in WD Blue and Black (SN770 etc), so these chips have a slightly lower endurance, though it's not officially listed. The controller probably has no ability to create SLC memory, or if it does it's very low amount, like 10-20 GB.
The noname mStore may have a newer controller that can convert the whole TLC memory into pseudo-SLC so you basically will have around 80 GB of slc write cache.
So they're assuming this feature will extend the life of the memory, and therefore they may estimate a high number. It could be a bit inflated, but 300-400 TBW would not be impossible.
