My case doesn't have any proper hard drive cages, best way to mount it?
Solved by Blue4130,
1 hour ago, Zando_ said:That second photo is the HDD bay... there's slide-in plastic drive caddies that go in there, both my Corsair and Phanteks cases have used similar. Each OEM uses their own slightly different one, but I believe they're pretty standard between an OEM's own cases. If you can find the brand on the case anywhere, should be able to track down one of the drive caddies.
1 hour ago, King Minor said:Sorry for the dust if that causes issues. It isn't on the components, Going to clean it soon with a gpu upgrade.
It doesn't use caddys. The screws on the harddrives slot into the grooves. My current case is EXACTLY the same and I have two drives currently mounted bare.
