Is it okay to daisy chain a 7800xt?
Vex828
The psu I’m using is the corsair rm750e, I’ve been seeing so much mixed information, some people say it’s okay, some say it’ll start a fire.
Get that white wire out of there, and no fires will happen.
(if you don't move the white wire, no fires will happen either, but that doesn't induce fear like the implication does)  🙂
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
I would, but it’s for the fan and there was no other slots on my motherboard
Can you not route it behind the motherboard or is it not long enough?
Do you really think the PSU brand would include daisy chained cables if they're a fire hazard? It's fine. I've been using a 3080 off a daisy chained connector for almost 3 years now and there haven't been any issues.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
7800XT draws max 270W, so max 200W are needed out of the Pcie cable, they're rated for 150W technically but can stand double, so no issue
But why did you twist/knot the cable ? 😮
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
7 minutes ago, Stahlmann said:
Do you really think the PSU brand would include daisy chained cables if they're a fire hazard? It's fine. I've been using a 3080 off a daisy chained connector for almost 5 years now and there haven't been any issues.
You've been using a card that has been out for less than 3.5 years, for almost 5 years?
That's impressive.
That's impressive.
Sorry it was a typo, corrected it...
You can use any daisy chained cables on GPUs with a TDP at or below 225W (cables delivering 150W of those). Any reputable company will also use HCS terminals, which makes them fine to deliver 300W. The RMe included.
Only sketchier companies (Seasonic is notorious for this) use regular Minifit Jr. terminals on their higher end PSUs.
I don’t think I can, gpus pretty large not too much clearance, cord doesn’t get hit though
But why did you twist/knot the cable ? 😮 If I didn’t it would have been upside down
Twist it near the PSU so the twist can't be seen
And shouldn't you rather flip the PSU upside down? Is there some perforation on the bottom of the case for the PSU fan ?
The psu is flipped upside down, fans facing down I guess that’s just how they have the logo
