Quiet high performance fans
rippy4500
I want quieter fans, I use open back headphones so I can hear any noise coming from my pc. Ideally I want to get the noise as low as possible without sacrificing performance.
Requirements:
-No rgb, black color scheme
-120mm
I have 3 intakes on the front with my 360mm aio and 2 exhausts, 1 on top and 1 on the back. So 5 total.
I also have just enough fan headers on my mobo so I shouldnt need any splitters or fan controllers, I have 4 system fan headers and 2 cpu fan headers (One taken up by aio).
I heard the Noctua NF-A12x25s are among the best when it comes to noise/performance ratio so im gonna get those if I cant find anything better.
PC Specifications: Intel i9-14900KF, 5.9GHz all core locked, 5GHz ring, 1.45v Medium LLC, E-cores and HT disabled | MSI RTX 4090 Gaming X Trio | Arctic Liquid Freezer II 360 + Thermal Grizzly contact frame | 2x16 G.Skill Trident Z5 7400MHz 34-44-44-34 1T 1.45v (Tuned Subtimings, Hynix A-Die) | Gigabyte Z790 AORUS Elite AX | Windows 10 Home 64-Bit EVGA SuperNOVA 1000 T2 Phanteks P400A (Black non-rgb version, Phanteks T30 fans 3 intake (On AIO), 1 exhaust) | SK Hynix Platinum P41 2TB PCIE 4.0 (Boot drive), Samsung 870 EVO 2TB SATA
Displays: MSI MAG 271QPX 1440p 360Hz 27" QD-OLED | LG UltraGear 27GP950-B, 4K 144Hz (@120hz) 27" IPS
Desktop Audio: STAX SR-007 MK2 Electrostatic Headphones | STAX SRM-400S Amp | Schiit Bifrost 2/64 (NOS mode, USB in, XLR out)
Mobile Audio: Sennheiser IE 900 IEMs using included 4.4mm cable | FiiO KA13 "Desktop mode" Disabled
Peripherals: Razer Huntsman V2 Full size wired with linear optical switch | Logitech G502 Hero
put the computer in a different room or outside the door.
costs zero dollars , sacrifices nothing , 100% silent
Unfortunately my setup doesnt allow for that for various reasons.
7 minutes ago, rippy4500 said:
with my 360mm aio
aren't you just going to hear the AIO fans though?
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
No id be replacing the aio fans
I spent a while looking at fans when I needed to upgrade mine. For me BeQuiet!'s Silent Wings 4 Pro's won. New designs, build quality is great, anti vibration mounting, high RPM hums is also much deeper than other fans, in theory loudness should be less annoying due to frequency of hum being in the "less perceived frequency" (I know little about audio terminology), yet what won it for me was it's radiator performance. Great static pressure with very little bleed anywhere, forcing all air through the radiator not through the side mounts.
To my knowledge Phanteks T30's were Nr. 1 but they're also thicker, didn't want to risk them not fitting my case. I'm happy with 2nd best. As far as I remember Noctua was competitive until a rad was added. Still better than 90% out there but margins were bigger.
They're a solid recommendation from me. You can check my PCPartPicker footer for how they look IRL. I've also got open back headset and don't really hear the fans. GPU fans themselves are louder.
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro Corsair K70 LUX browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
ah ok does the room not have a door?
Yeah but its on the other side of the room from my setup meaning id need excessively long cables which could be expensive and less reliable. And also I dont wanna have to leave my chair every time I need to interact with my pc itself. I just dont want the extra hassle/jank that comes with a weird setup like this, if I could even do it at all.
-120mm
Ideally you'd just properly tune your fan curves. I don't hear my machine at all 90% of the time and its 3 feet from me. 7800x3d/4090, all air cooled in a Fractal Torrent. I don't ramp the fans up above 40% PWM until the CPU hits 85c but that only happens there is a full multicore load which I don't do often. At that point they ramp to 60% PWM.
I think curves following CPU temp directly up and down is annoying as hell, and completely useless for water cooled CPU's.
If you are limited to 120's (bigger is better) then just get some T30's and be done with it.
Yeah, good curves are half the job, Fan Control is a great app for that.
I'd recommend a bundle of 5 Arctic P12 for around 30bucks (though I'd recommend having one or two spare, in case one is noisier from scratch)
(How do I tag another writer ?)
Edited by leclod
I'm willing to swim against the current.
I agree with this to an almost aggressive point. The fan curve for my system has the AIO (and system, though they bottom out a little higher) fans at 450RPM until 65C, then it's 650RPM all the way until 95C where I have to make them go full bore. The only thing that ramps with CPU temp is the pump speed: 800RPM until 55C, 1200 to 65, 1600 to 75, and then whatever the hell max is starting at 80.
My system is functionally inaudible at idle or low load, and the loudest thing by far under load is my 2080 as well as when the PSU fan kicks on. All with no sacrifice to temps, even though I have an SFF build with essentially fully open side panels.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
I have exactly those but they are audible to me at higher speeds. Supposedly better fans like the be quiet Silent wings 4 or Phanteks T30 are quieter at the same rpms though.
Looking into it now the T30s look really good according to some places online. And I think id be able to fit them without issue.
My system is functionally inaudible at idle or low load, and the loudest thing by far under load is my 2080 as well as when the PSU fan kicks on. All with no sacrifice to temps.
I have to remind people, with liquid cooling the fans are not there to cool the CPU, they are cooling the water. The water is going to change temperature drastically slower than the CPU.
I wish more AIO's offered a way to monitor water temperature and a better way to implement triggering fans off of it that was more universal.
A buddy of mine running a Commander Pro is using one of them the temp probe inputs to monitor radiator exhaust temp and triggering his fans off of that which I thought was pretty nice. It works well.
Requirements:
-120mm
What's your case ?
I suspect removing the top fan won't change anything, so you need 6
Noctua NF-A12x25s will be fine, I'd still get a pair of 3 to 1 splitter so you can have all the AIO fans and all the intake ones on the same curve, it makes no sense to have 6 curves...
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
That all being said more often than not when looking at situations where people complain about fan noise, its often solvable simply with curve tuning and nothing else. Things don't always have to be down at x temperature when y gets you the same performance with less noise.
Yup, that's the one and only thing I miss about my H115i and iCUE: where my AIO was cooling the CPU as well as serving as the exhaust for my entire system, I was able to have the fans ramp according to liquid temp to keep both the CPU temps in check as well as the liquid temps.
Main rig on profile
VAULT - File Server
Requirements:
-120mm
You have a 14900K, you're never going to achieve quiet without retarding that thing to unreasonable levels.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
All fans are audible at higher speeds. Noctua won't make a difference in my opinion.
The reviews I've seen don't show a big gap between all the better fans, if at all.
My P12s in my system top out at around 1400rpm,  which is still very decent noisewise.
How fast do yours spin and for what temps ? maybe increase the temps and lower the speeds ?
Edited by leclod
all you need is an ethernet cable and a slim client on your side,even with the best fans in the world a cooler capable of cooling the 14900k will make noise and you'll be dissapointed with the results
if you are serious about this, this is the best way
Bro's gonna need a 420mm AIO at the lowest if not going custom outright. All core load is unsustainable. Pretty sure IceGiant would not even handle all core load.
My P12 in my system top out at around 1400rpm,  which is still very decent.
How fast do yours get and for what temps ? maybe increase the temps and lower the speeds ?
I just set them to 40% (or maybe 50% i forgot), its at a level where its tolerable and keeps my temps low enough. And also I find variations in noise way more noticable than 1 consistent noise level so thats why I locked them.
gpu is 40c idle and 75c under furmark
cpu is 40c idle and 85c under stress test and like 50-60c while gaming or with modest workloads. (14900kf, 5.9 allcore locked, ht and e-core disabled)
@GuiltySpark_@Dedayog@PDifolco @venomtail  what about different case that lets less noise bleed out, would that sorta solve OP's issue?
PC:
PCs I used before:
It's not just he fan that makes noise.  Air itself makes noise as it moves around things, like the case.
That's why we hear wind outside our houses.
Purse your lips and blow out of your mouth hard.  Your lungs are silent as they push the air, but noise is heard due to the air moving out of your mouth.
To get adequate cooling, you need air.  In a case, which is a controlled space, you have to move sufficient air to remove heat.  This air is a formula of air speed and air volume.  This results in an amount of air that moves at a speed, which means noise.
In a computer case, there are ways to reduce this but not fully.
OnePlus:
Other Tech:
Don't think it'll change much, fans have to get air and don't like closed panels, noise don't like mesh...
