Frame rate woes again, is it Vegas?
Solved by porina,
Just tried the same file in Vegas 19, at 59.94 fps timeline. I don't see the effect happening, although I can't say I tested the exact same spot I saw the problem in 16 as I forgot to note where exactly that was. I did try various locations in 19 and none of them did it, so I'm going to put this one down to 16 being old enough to have some problems.
Guess this is more incentive for me to make the switch to the newer version.
