How are Forum "Ranks" unlocked?
Solved by IkeaGnome,
Posts, reacts, comments being marked as solution. Off topic posts don't count, since they don't count for your post count.
1 minute ago, suchamoneypit said:Cant seem to find any information on how they are unlocked or how you progress to the next tier.
Make your window smaller. You can see it when you get small enough to go to the mobile view.
Obligatory ranks don't matter ;).
Welcome back!
