At noon (Pacific) today, Twitter open sourced the recommendation algorithm of Twitter.  This has been hinted at for the last few months, but today it's finally released.  There are portions of the algorithm which remain still closed source but will apparently be added as time goes by.  There is a lot of code and documentation now to dive through
Twitter takes its algorithm ‘open-source,’ as Elon Musk promised - The Verge
Quote
Twitter has released the code that chooses which tweets show up on your timeline to GitHub and has put out a blog post explaining the decision. It breaks down what the algorithm looks at when determining which tweets to feature in the For You timeline and how it ranks and filters them.
According to Twitter’s blog post, “the recommendation pipeline is made up of three main stages.” First, it gathers “the best Tweets from different recommendation sources,” then it ranks those tweets with “a machine learning model.” Lastly, it filters out tweets from people you’ve blocked, tweets you’ve already seen, or tweets that are not safe for work, before putting them on your timeline.
GitHub - twitter/the-algorithm: Source code for Twitter's Recommendation Algorithm
It will be interesting to see what comes about this, at the very least it adds a bit more transparency in regards to the algorithm.  I'm sure as people pick it apart they will find tid-bits of information and in general be able to make a more neutral algorithm.  Twitter is apparently building towards accepting pull requests from users as well, this sort of reminds me of when Google made Chromium and open-sourced it though.
Time will tell to see what happens with the source code though, and whether or not 3rd party input will be accepted into the algorithm.
3735928559 - Beware of the dead beef
Note the Elon priority as well as US politician Tweets: https://github.com/twitter/the-algorithm/blob/7f90d0ca342b928b479b512ec51ac2c3821f5922/home-mixer/server/src/main/scala/com/twitter/home_mixer/functional_component/decorator/HomeTweetTypePredicates.scala#L225
  "author_is_elon",
  candidate =>
  candidate
  .getOrElse(AuthorIdFeature, None).contains(candidate.getOrElse(DDGStatsElonFeature, 0L))),
  "author_is_power_user",
  candidate =>
  candidate
  .exists(candidate.getOrElse(DDGStatsVitsFeature, Set.empty[Long]).contains)),
  "author_is_democrat",
  candidate =>
  candidate
  .exists(candidate.getOrElse(DDGStatsDemocratsFeature, Set.empty[Long]).contains)),
  "author_is_republican",
  candidate =>
  candidate
  .exists(candidate.getOrElse(DDGStatsRepublicansFeature, Set.empty[Long]).contains)),
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
An Ars Tecnica article reports that that piece of code might be collection of metrics:
Twitter posts the code it claims determines which tweets people see, and why | Ars Technica
The actual algorithm is degeneracy, toxicity, depravity and filth aka people.
Anyway, next maybe FB or better yet YT that be funny.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
I see.
So it seems like this code is for collecting metrics and not actually a "visibility boost", yet people automatically assume it is because it would confirm their preconceived notions and hopes. Some piece of code mentions Elon? Gotta be evidence for my conspiracy theory I believe in! Who cares what the code actually does, it probably just does what I assume it does!
Based on?  The variable literally has the word stats in the name which implies its used for tracking.
Then looking at the code base and where the variable is used you get this fine comment right above that section
https://github.com/twitter/the-algorithm/blob/7f90d0ca342b928b479b512ec51ac2c3821f5922/home-mixer/server/src/main/scala/com/twitter/home_mixer/functional_component/feature_hydrator/RequestQueryFeatureHydrator.scala#L86
Quote
       * These author ID lists are used purely for metrics collection. We track how often we are
       * serving Tweets from these authors and how often their tweets are being impressed by users.
       * This helps us validate in our A/B experimentation platform that we do not ship changes
       * that negatively impacts one group over others.
Congratulations, that code snippet you posted relates to metrics collection.
Art Twitter has been linking to this thread:
Let's be honest, the algorithm punishes external content, and only promotes what is hosted on it.
Quote
• Each like gets a 30x boost
• Each retweet a 20x
• Each reply only 1x
Quote
Links hurt, unless you have enough engagement
Generally external links get you marked as spam.
Unless you have enough engagement.
This one is probably the one that will hurt the most:
Quote
• Mutes
• Blocks
• Unfollows
• Spam reports
• Abuse reports
So that means, that if you are controversial in the slightest, your discovery is getting destroyed.
On 3/31/2023 at 4:43 PM, OhYou_ said:
They should rewrite the entire codebase in Rust
Not sure if joking, but I un-ironically agree.
CPU: Ryzen 5950X Ram: Corsair Vengeance 32GB DDR4 3600 CL14 | Graphics: GIGABYTE GAMING OC RTX 3090 |  Mobo: GIGABYTE B550 AORUS MASTER | Storage: SEAGATE FIRECUDA 520 2TB PSU: Be Quiet! Dark Power Pro 12 - 1500W | Monitor: Acer Predator XB271HU & LG C1
