No Breaks(UPS) for a 850w PSU (Seasonic FOCUS GM)
25 minutes ago, Poinkachu said:Maybe @manikyath can give insight ?
my 'rule of thumb' is this:
- run everything you want to run off the UPS at full tilt, note the wattage (use one of those power plug wattmeters if you must, they cost like 15 bucks..)
- double that wattage (because ideally you dont go past 50% for battery lifetime reasons.)
- find a decent UPS that as a WATTS rating (not the VA rating) that's close to or above that double wattage.
about the watts / VA thing: UPS'es assume that what you wire up to them will have a horrid power factor, which means they can delver more volt-amps than they can deliver watts. and because VA is the bigger number, that's what is on the box. but down in the spec sheet they should state how many watts it can deliver. if it doesnt, ignore the product anyways.
beyond that.. i generally avoid units that have a single 12V battery for running 'actual load' (they do great for stuff like network equipment), because they just get beat up too hard to get decent lifetime out of them. just a handful of power cuts will ruin the battery.
as for an actual brand recommendation, all of my stuff is APC back-ups, and my only complaint is that replacing the batteries isnt quite as streamlined as one would prefer (the 1400VA units basicly need to be dismantled with some force..)
they're all stepped approximation sine wave, which isnt ideal.. but other than making my power supplies a bit screamy it hasnt been an issue.
