Help a Noob pick his first DAC
Lord Szechenyi
 Share
Go to solution Solved by Lord Szechenyi,
Oh forgot to update, I already picked the Fiio K3
Hi
Just bought an HD600 and need to get myself a DAC
I was thinking of either getting the Fiio K3 or the Creative Sound Blaster X4 (which is an external sound card, I know).
Unless I should pick something completely different, idk.
I don't want to buy something expensive, but I also won't cheap out, I'll pay at least 50€, but 200€ would be the hard limit for me.
38 minutes ago, Lord Szechenyi said:
Hi
A fantastic starting out DAC and AMP setup is the schiit stack. A schiit Magni and Modi are a fsnstastic 200 dollar setup (100 each last I looked).
You need an amp after your DAC, thus the reason for this recommendation of both.
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 64 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - 10TB WD Red for expendable data - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
would recommend any entry level schiit and ifi dac/amp. fiio has some very good dac+amp 2in1 dongles like the jadeaudio ka3 but not sure about their full sized counterparts. at this price range i'd put more thought behind amp as it can change the sound drastically. hd600 has fantastic timbre in the mids and low treble. but it's sub bass roll-off is also severe. people tend to go with amps that can bring out hd600's sub base while retaining the quality mid range. watch some youtube videos about schiit and ifi products, note down what you think you might like, then go to your local audio store to test them out.
I want something which does both
edit : I checked, the modi 3 is 200€ on it's own, so way over my budget
it depends on how bad your onboard audio is but in my experience i got a 200 dollar dac and it didnt sound much better than my amp connected to my computer. so i usually recommend people to just get an amp for now or an amp with a dongle for the dac
I'll have to test out my onboard with some of my amp's, in the past I never used line-out so it was double amping and sounded like hot garbage.  But I should test it just to know.  I have a $500 dac/amp and recently went to a $400-500 stand alone dac and the dac does sound better but not enough to justify the price tag.  Rather I needed another dac for my future tech cave and I wanted balanced and Bluetooth so I went for a nicer one.  I wouldn't suggest a dongle dac because they're dac/amp's which is going to double amp making it sound like garbage.  I tried this with an apple dongle dac and budget amp and it was no bueno.  Also I always thought Fiio were good to recommend but later looked at their spec sheets and they don't put out much power?  Maybe the specs aren't everything but I was shocked at how low the numbers were for mw at different ohms.
Considering that the currency isn't in USD I'm going to imagine Schiit isn't a viable option, they're very expensive outside of north america.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Noir - AKG K361-BT - Blon BL-B60 - Hifiman Rd7x - Blue Microphones Lola - *Beyerdynamic DT770-80
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Sybasonic SD-DAC63116 - Fosi Q4
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Are you JUST looking to power your headphones, or are you looking for something that can take audio input as well?
Please take everything I say with a healthy dose of Googling.
Well I obviously want the audio input for my pc (otherwise what am I going to listen to), but otherwise no, just for my headphones
Sorry, I suppose I could have phrased that a bit better. Are you just needing to listen to music, or do you want the ability to power a mic down the road as well?
Nope, just for listening
JDS Labs Atom DAC + Amp
OR
Topping D10S + L30 II (make sure it's the II)
 Share
