Best OLED monitor?
On 1/21/2023 at 1:45 AM, xc3ll said:Has anyone results on hardcore burn-in tests on the existing OLEDs in Laptops or the Alienware?
I am *very* careful with my OLED TV an notice some slight burn in on plain gray surfaces from time to time. If I would use it as a monitor for 100hr, it would definetly have noticeable effects...
EDIT: I do not want to make any statement to the reliability of OLED monitors. It is definetly a different kind of technology, than my first-gen TV. Just asking a genuine question about data on that.
I've been using my LG C2 for hundreds of hours of desktop useage and gaming since i got it a few months back. So far there is no sign of burn in. The issue you're describing is probably just temporary image retention, which goes away in a few minutes.
So on the topic at hand:
At 27" i'd say the LG one will be the obvious choice. They all use the same panel, so the main diffrence will come down to small details and the price. The Acer and Asus variants are already marketed with a $100 premium or more.
The 45" ultrawides all have the same dealbreaking issue: Pixel density. They're a no-go from me.
In the 42" space the LG C2 is the obvious choice, as it's pricing is extremely aggressive.
On the 34" front the Dell AW3423DWF seems to be the best atm.
TL:DR:
The upcoming 27" 240Hz monitors will probably take the cake for "best overall gaming monitors" but in-depth reviews are still pending.
