Budget (including currency): ~1500 USD
Country: United States
Games, programs or workloads that it will be used for: Fortnite, Cyberpunk, GTA VI (if it ever gets ported), D:BH, etc.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): hopefully will be getting this for my birthday (May 25) or not long after. 1440p at 165hz or higher.
Current parts list: https://pcpartpicker.com/user/m0oble/saved/3kbTrH (CPU, motherboard, and RAM price is from a microcenter bundle)
Current PC: https://pcpartpicker.com/user/m0oble/saved/HYGTmG (1080p 144hz)
I do not want to go with intel for my CPU, and probably not GPU either unless they randomly drop some bomb ass products.
Willing to go with AMD or Nvidia for my GPU.
pc specs:
PCPartPicker Part List: https://pcpartpicker.com/list/WxtJMC
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($199.99)
CPU Cooler: be quiet! Pure Rock Slim 2 CPU Cooler  ($20.00)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($70.00)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($80.00)
Storage: Western Digital Blue SN570 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($90.00)
Storage: Western Digital Blue 6 TB 3.5" 5400 RPM Internal Hard Drive  ($110.00)
Video Card: PowerColor Hellhound Radeon RX 6600 XT 8 GB Video Card  ($400.00)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($99.99)
Power Supply: Thermaltake Toughpower GF1 (2024) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($88.99)
Total: $1238.97
https://linustechtips.com/topic/1569210-possible-birthday-build-feedback/
6 minutes ago, leclod said:
Seems very fine to me
(why don't you keep your case, psu and ssd ?)
case bc I want to keep this PC I have rn as a still complete build
psu is so bad that it isn't even on pcpartpicker, it's a tier E redragon 700w bronze
current SSD will be put in the new PC for extra storage, just not keeping it as main storage because of its age and speeds (bought it dec 2021)
pc specs:
Total: $1238.97
I wouldn't waste any money on those cables. Especially not cheap ones. You can spray paint them red if you want, just tape off the clips.
You can totally do a 7900GRE for your budget, too, and this one has a black and red motif.
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($379.99)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: MSI PRO B650-P WIFI ATX AM5 Motherboard  ($0.00)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  ($0.00)
Storage: Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($139.99 @ Amazon)
Storage: Western Digital Blue 6 TB 3.5" 5400 RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: Sapphire PULSE Radeon RX 7900 GRE 16 GB Video Card  ($539.98 @ Newegg)
Case: Fractal Design Pop Air RGB ATX Mid Tower Case  ($89.99 @ B&H)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.00 @ MSI)
Monitor: MSI G272QPF 27.0" 2560 x 1440 170 Hz Monitor  ($219.99 @ Newegg)
Total: $1492.84
Generated by PCPartPicker 2024-05-05 18:45 EDT-0400
I edit the shit out of my posts.  Refresh before you respond.
