Noctua fan recommendations for Fractal North Mesh
vladonizer
I am looking at building in this case soon and was planning on using Noctua fans because I've heard they perform great with low noise an I really like the color. I want to occupy every fan mount with the most efficient fan specific for that spot and mesh/filter it may have to pull air through and am looking for recommendations on the specific ones that will work the best for using lower RPMs. If they perform well at quiet levels I am willing to use the stock case fans with the Noctua fans: Just don't know much about them
3x120mm fans in front with for intake
1x120mm fan in back for exhaust
2x(120 or 140)mm fans in top for exhaust
2x(120 or 140)mm fans on side panel for intake
Just put NF A12x25 s everywhere for a brownish visual party 🙂
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Would it be better to do those at the front intakes, maybe NF-A14 for side intake and top exhaust and a NF-S12a for back exhaust since there won't be resistance there?
Really NF A12 are good as well as case fans than on a rad
Mixing 120 and 140mm may result in a worse overall look, and need 2 curves as they don't have same speed
And I doubt performance will be any different in both cases
I will not really be able to see the fans unless I take the mesh side panel off(using this case: https://www.fractal-design.com/products/cases/north/north/charcoal-black/ ) I just thought the side intake might work better with 140s and I will of course use a Noctua air cooler on my CPU. I was also planning on setting the curves differently on the fans blowing on the GPU than the cpu. But if the A12's would perform the same, then I guess it doesn't really matter?
9 minutes ago, vladonizer said:
... But if the A12's would perform the same, then I guess it doesn't really matter?
Yes mostly !
BTW if you're not completely taken by Noctua-itis and won't see the fans, you could get Arctic P12s for 20% of the price with 95% of the performance , and noise won't be a concern as case fans are usually on lowish speed (50%)
From their website it looks more like half the price, but still does save a lot of money
Edit: Nevermind, I wasn't looking at the 5 packs
P12's aren't as quiet as NF-A12x25's.
True overall, but at 1000rpm or below (which should be fast enough for case fans) you won't hear any of them, and be richer by $200 (for 8 fans) 😛
Most fans above 500rpm are audible to me unless there's a solid panel blocking them.
1000rpm fans are far from quiet for almost all fans and too noisy for idle.
At 500rpm most people won't hear anything unless in a really silent environment, but that's quite a personal taste/sense
However difference between Noctuas and Arctic (or anything else) is then really negligible
I am just here to shamelessly plug Phanteks T30s as they are superior to any Noctua fan
CPU-AMD Ryzen 7 7800X3D GPU- RTX 4070 SUPER FE MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Maya+ 4k Dongle+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
You're right too, but spending $30 to $40 x8 for case fans is just kinda silly imho
T30s are for rads/heatsinks
Plus they're even uglier than Noctuas  😛
They're kind of subdued looking, not the best but not the worst IMO. They have RGB T30s coming out in March though with slightly less performance.
