12700 build vs 12600K build?
Going to upgrade my CPU, Which build would you prefer?
I've no intension of overclocking, Specially for now.
1ST BUILD
I7 12700 with MSI PRO B660M-A DDR4 12th Gen Micro-ATX Motherboard
2ND BUILD
I5 12600K with MSI PRO Z690-A DDR4 12TH GEN LGA 1700 Intel ATX Motherboard
I'll be gaming on this build, But mostly I'll do 3D modeling and rendering stuff.
One thing i've noticed about 12700 is it has only 2.2Ghz of base clock, but has 4.8Ghz turbo boost.
So is that low base clock going to slow down anything compared to 12600k? specially when it'll come to gaming & rendering (I'll get good after market cooler of course)
And please don't suggest anything like 12700K or 12600 please, It's either too expensive here, or out of stock.
I went with 12700. More P cores seems better to me. The base clock doesn't matter, it boosts forever on properly unlocked power limits. So the difference is 100Mhz between them.
Ah I see, Thanks for letting me know
And what about the B series mobo that I chose? is it good enough for 12700?
Yes. MSI PRO A boards are good enough for the i7.
Just now, KaitouX said:
As long as you give the 12700 enough cooling and power it's going to be faster than the 12600K in most tasks. Here's a review showing the 12700 at stock and no power limit: https://www.techspot.com/review/2391-intel-core-i7-12700/
But it might be worth waiting for the 13600K to see if it's a good option.
I was actually waiting for 13600K actually
But because of inflation and many reason it's not a good option for me anymore
New X series mobo came, it's 289$ In amazon, and it's 450$ here.
So i'm guessing 13600k would be something around 500$.
12700 is still 370-400$ So I might go with this one.
13600k preorders for less than $400 so you should consider it
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
1ST BUILD
2ND BUILD
Neither. 13700k
CPU-AMD Ryzen 7 7800X3D GPU- RTX 4070 SUPER FE MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Maya+ 4k Dongle+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
1 hour ago, CHICKSLAYA said:
Neither. 13700k
How can he get a 13700K if the 12700K is already too expensive ?
hahah exactly, 13700k will be around 600USD here.
I missed that part, my bad. I'd get the 12700 with b660
