Can’t figure out how to turn the motherboard on
Solved by Veehxia,
8 minutes ago, thesilverderp said:I have read and heard that all that you need to do to turn on the motherboard outside of the case is to short the two pins that are labeled PWR. My motherboard does not have pins labeled power, but it does have pins labeled reset.
The PWR pins are the 2 above the reset ones.
It's a standard layout, look in your MB manual.
Those 2 are the ones you need to short to boot it up.
