FIIO K5PRO ESS Setup
Aside from drivers, the DAC should function properly without any additional assistance. DSD playback should also be fully functional out of box as far as I'm aware. That's not really a feature to enable/disable, it's just a supported audio codec. In order to even use it, you need access to DSD files. Same goes for FLAC, just a supported codec. ASIO on the other hand is set on a more program-by-program basis. It's an audio driver intended for low-latency use when it matters. For example, I only use it when I'm in FL Studio.
When it comes to the bit-depth and sample rate settings, they don't really matter much. They're more of a potential output setting, they won't impact sound quality in any way unless the bit-depth or sample rate of the file you're playing is higher than your DACs output setting. Some programs won't function properly on too high of a setting though. For example, Foobar2000 (at least my version) bugs out if I have my DAC set to anything higher than 24-bit/192kHz. Again though, if you don't have files of that resolution you'll notice no difference.
Unless you have a Quobuz or Amazon Music subscription, pay thousands for hi-res digital copies of all your music, or are playing Cap'n Jack Sparrow breaking copyright laws, you won't be accessing files of that caliber anyways. I use a combination of all of the above, mostly the latter.
