Urgent Help RTX 3060 vs RTX 3070
Solved by Origami Cactus,
A jump from rx480 to any of those cards will be a big jump, thanks to Nvidia CUDA, you can use that as your GPU renderer.
If you don't edit 8k, the 8GB of rtx3070 should be enough.
No, going from 32gb to 64gb won't double any of your performance, 32gb should be enough in your workloads, so no improvement.
