concerns regarding cable length and type
10 hours ago, Alex Atkin UK said:Are you sure? Ubiquiti make quite a big song and dance about needing shielded cable for their outdoor equipment because there is so much more background RF outdoors that can get into the cable.
I'd personally not want to use UTP, especially given the length. Also a benefit if there is a lightening strike nearby it can induce current in the cable (it happened with my phone line and blow up the modem) so having a grounded shielded cable seems a good idea. Or go the more expensive but safer route and use fibre, although I'm not familiar with the price of outdoor rated fibre and you'd need bigger holes to get the pre-terminated ends through.
The shielding is good for noise or RF environments mainly industrial environements. For exterior if it's being mounted on an aerial for sure you will want shielded cable for lighting protection or grounding but as this is being put on a structure itself I would be less worried as if lighting struck the structure itself there would be much larger issues than with just the ethernet devices being fried.
16 hours ago, Nuh_ said:It'd love to test this. Is it as straight forward at getting the equipment and hoping it works? because it's an old house and I don't trust how it's wired.
or is there something I can do beforehand to ensure it works?
There isn't really an easy way to test but depends on how old the home is and if the wiring has been upgraded. If the electrical panel has been upgraded at some point with breakers or fault interrupts over glass fuses I would bet a good bit has been redone in the home.
If cost is an issue and wiring a hassle I would first try a powerline solution before spending a lot more time and work having to get cable installed and mounted on the side of the building.
