Where to plug in second CPU fan?
Solved by Alex Atkin UK,
2 minutes ago, Tacitus said:Hey all
Currently building my new pc. I have 2 CPU fans, but my motherboard only has 1 CPU fan connector. It's a 2A connector. I also have a pump fan connector (3A, PWM), and a system fan connector (1A, DC). Am I fine to plug the second CPU fan into the Pump fan connector and do I then need to do anything in the bios to get the two fans to run in sync?
Thanks all
Does the cooler not come with a Y adapter to plug them both into the same fan connector?
