What AIO for a threadripper 3960x?
Solved by Kilrah,
3 minutes ago, BelviGER said:Wait so the cooler doesn't need to cover the entire IHS?
The heat spreader is there precisely to collect the heat, so as long as some part of it is being cooled it'll get heat away - but obviously not ideal.
3 minutes ago, BelviGER said:I just really couldn't be bothered in a case I won't look into, ever
Then just slap some quick flexible tube instead?
