Seller called me and told me my card will die and he will replace it
Drevo
Hello, yesterday I bought second handed GIGABYTE AORUS GTX 1080 Rev. 2.0 I install drivers, etc. everything work fine. Today seller called me and said my card will die in few days because of something his friend did to card. He assured me he will replaced it for same, which will work. I am not sure if its scam. What I am concered is card´s BIOS which on techpowerup is unverified. What should I do?sasasa.thumb.png.4f7b0f721e98a96906c1330c0976db84.png
https://www.techpowerup.com/vgabios/197393/197393
bench it and comapare to other gtx 1080s, if the scroes are similar you are fine
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Run 3dmark time spy: 7649 gpu score.
Edit: average score on 3dmark is: 7601
yeah seem legit, do not send the gpu back to the seller, seems scammy
Main PC:
Test Rig.
Just Sold
Ask me anything :)
Where'd you buy it from?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
He live in same city as me and asked me to come to him and try replacement card for myself
Unless you can get some detail on what is supposedly wrong with the card, don't do a damn thing.
you can also ask what (if) his friend did anythign to it.
having 2x the same 1080 is not common with normal people.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
Might be a way to try to get you to ship the card back first. I would not do that.
He is getting them from his friend in ukraine, he told me that he dont know what his friend did to it and he is ashamed of it
but how he knows when somethign is wrong, when he does not knwo what is wrong?
check temps, voltages, adn power usage, if they are normal, then nothing is wrong
Main PC:
Test Rig.
Just Sold
Ask me anything :)
Tested in occt for 1 hour and no problems whatever
Probably he tempered with gpu bios, thats my concern since on techpowerup is not verified
Bios is ok, found it on gigabyte site. I opened gpu, repaste it and used lens to check almost every condensator. Nothing damaged. He probably want to sell it for more. Bought it for 450euros
Can you just flash that official Gigabyte BIOS and then maybe you can stop worrying in the long run?  The rest seems fine.  That seller seems sketchy.
