Best 12600K cooler under $100?
sdw123
Stock settings 'll be more than enough for my work. So if a $60 can perform okay, I'll take that. 😁
What case and ram are you using?
Just make sure it comes with / you order the socket 1700 bracket along with it.
If it fits the budget i'd go Noctua U14S. These chips can get quite hot.
